Question about Apple MacBook Pro Notebook
Lap tops does any of the laptops able to be plugged into a 240 outlet or is there any laptops that have a 240 plug for that outlet
  • 4 Answers
All fairly modern Apple laptops work fine with 240v power.  It should even say so on the power brick for the unit.  You just need an inexpensive adapter to convert from the 110 style plug to the 240 style plug.
Posted on May 26, 2008
    Scholar:
  • 143 Answers
It sounds like what you are looking for is a Step up/Step down converter. I do not know of any laptops that come with a 240v adapter since most things here in the U.S. run on 110v.
Do a search on Google or such for a 240v 100v converter.
Posted on May 22, 2008
Lap top screen only shows background picture
Does the mouse work? I would Cold-stat the machine: 1) remove AC plug from outlet, 2) remove battery, 3) hold down on/off button for 10 seconds, 4) replace battery, 5) plug into wall outlet 6) push on/off button.let me know if there is any change, if not you can try another procedure.
Nov 01, 2012 | Compaq Computers & Internet
Orange battery light comes on and the computer says low battery. Computer does not work even when plugged in to wall outlet. I don't think it is the adapter because blue ring on plug in to the com
Diagonizing and analysing this problem, it's obvious that the orange light means battery low.
Have u ever tried charging the laptop with another charger/adapter?
If no try it because some adapters/chargers don't work with some laptops. Also be careful to use the recommended adapter, some can spoil the laptop's panel.
Jul 23, 2012 | Dell Studio 15 Laptop
Can i change the plug socket over from 110v to 240v supply on my HR2470T-1/1
It would not be OSHA approved if in the US in an industrial location.
While not recomended practice, it can be done in the US to run off of 4 wire 240. You are just connecting to one half of the 240 outlet.
If you are in the UK or elsewhere with 240/250 volt mains- do not do this, use a voltage reducing transformer instead..
In the US, the standard is 120 /240 Or put another way- a 240 volt circuit in the home in the US, has 2 120 volt branches that share a common return, the 240 is derived across the 2 "120 sources"- hence your 2 pole breakers on 240 volt branches. If the socket is 3 terminal- which was old code- ground and the return were common at the outlet, it is a matter of just making sure the 240 volt plug terminals the 120 volt drill gets attached to is the ground/return (the one with the nib on it to make it index correctly in the outlet- (should be the wide blade lead or white and one black in the drill goes to either"hot" side of the plug- either one will work, and only one. On a 4 wire outlet, which is new code- the return goes to the white wire of the drill. And the black goes to either one of the hot sides. If drill has conductive case and grounding wire- that should connect to the outlet ground.
Mark on plug which two blades are used, so if you take it somewhere else, you can check (which should be standard operating procedure) with a meter to make sure their outlet is wired correctly.
Feb 11, 2012 | Drills
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
When the lap top logs off front light stays on
Do you still have the power cord plugged in? There are indicator light s for Battery operation, power on, hard drive activity. If you just logged off but the laptop is stillpowered on, then there will be a light indicating that. If you powered off the laptop but left it plugged into a wall outlet, then there is a chrging indicator that will stay lit.
Sep 11, 2009 | Dell Inspiron 6000 Notebook
B&D 400W Inverter won`t run my laptop
even the smallest inverter can run a laptop, something is wrong with this unit
Jul 25, 2009 | Black & Decker 1000w Power Inverter
Cut battery off
If it is plugged in, and still running from the battery, you likely have a bad adapter or power jack. If you have a multimeter, set it in a range that would display 16v dc voltage, then stick the red inside the plug from the adapter, and touch the black to the outside of the plug, and see if the voltage registers (most IBM laptops use 16 volt adapters).
Feb 20, 2009 | Everex StepNote NC1500 Notebook
Kenmore electric dryer - plug too big for outlet
you need a 240 outlet box installed the only dryers that run on 120 are gas dryers you purchased an electric dryer and it needs 240 volts. you need to talk to your landlord and ask him or her to have a 240 outlet installed for you
Dec 29, 2008 | Home Maid CD250UT Dryer
Toshiba M55-S135
check your battery on some other's laptop, i think the battery life is over, you have to replace the battery
Oct 29, 2008 | Toshiba Satellite M55-S135 Notebook
Acer extensa 4620Z laptop computer will not re-charge battery. The cord going to the outlet has power...green light...but no lights are on lap top and it is securely pluged into lap top. - When I...
It could be one of three things. It could be a bad battery, a bad ac adapter, or the recharging circuitry could be bad. I would try pulling the battery out, and see if the laptop will startup and run strictly off of the ac adapter. If that does not work, you have a bad ac adapter. If that works, and the battery has any charge left, try running it strictly on the battery. If it doesnt work, you have a bad battery. If it does work, the circuitry is bad and you will probably need new motherboard. One other thing you can check is where the ac adapter and battery plug into the laptop, and make sure there is no corrosion that could be causing a short.
May 10, 2008 | Computers & Internet
Apple MacBook Pro Notebook Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
