Question about Roper RT12VKX Top Freezer Refrigerator
Roper 14 cubic foot refrigerator
It seems that the lower part doesn't feel as cold as it should be. The freezer is working excellent but it seems that the cold from the freezer is not getting down to the lower part.
Toward the back of the lower section in the ceiling I see 3 square holes that might be vents coming from the freezer. I can feel what seems to be foam in them. Was I supposed to take those foam pieces out?
I bought this frig brand new from Lowes 8 months ago and I can't find my instruction manual at the moment.
If I am supposed to take those foam pieces out, how do I do that?
Thanks for all your help.
Josephine
freetek
  • 5568 Answers
SOURCE: freezer cold refrigerator not cold
It almost sounds as if your fridge is stuck in a defrost cycle.
The timer for this is often located behind the grill at the bottom and sometimes is constructed with a visible shaft that you can mark to see if it is running at all. Some units are constructed so that the defrost heater and compressor can't be on together, others are made so thoughtful. If you don't see a shaft, you might try an old mechanic's trick of using a screwdriver with the tip pressed against the timer housing and the handle pressed firmly behind your ear for bone conduction. If you hear anything like motor noise during the time the compressor is not on, then the timer is probably OK. If you hear nothing, then it might have failed.
Posted on Oct 20, 2008
tzweeb
  • 318 Answers
SOURCE: 18 cubic foot roper is clicking, but not freezing.
yes the "relay" on your unit has burnt out. if you shake it and pepper looking pieces come out of it that will verify that you need to replace the relay.
nice work finding the exact problem by yourself and now all you have to do is buy a relay and plug it in to get things back to normal.
also be sure to clean the coils under the unit as when the compressor gets too hot it will cause the relay to fail. it is very common and you can fix this yourself.
Posted on Jan 07, 2009
localwonder
  • 6784 Answers
SOURCE: roper refrigerator freezer not freezing and bottom not cold
This is a compressor issue. Its probably done.
Posted on Feb 14, 2009
SOURCE: My freezer is okay but my refrigerator is not cold really.
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
  • 7 Answers
SOURCE: The lower refrigerator section is not cold anymore
check to see if the fan motor in the freezer is running. all the cooling happens in the freezer and the fan is what circulates the cold air down to the refrigerator.. if the fan isnt running ,it could be a bad connection or a bad fan motor..on some models the doors need to be closed before the fan comes on so just push on the door switch to check .if the fan is running then a defrost problem may be the problem.. you mentioned you defrosted the unit. if the auto defrost isnt working, you would notice frost on the back of the freezer. there would be a lot more frost behind that panel that could block the airflow down to the frig. you would have to remove rear panel of freezer to clear all the frost and restore proper airflow..remember to unplug the frig before doing any work..
Posted on Mar 25, 2010
How many cubic feet is the 106.5942801 model?
1 Open the refrigerator door. Measure the depth of the refrigerator
from the front edge of the refrigerator opening to the back wall. Make sure that you measure in feet and not in inches. Note the depth measurement on a piece of paper.
2 Measure the height and the width of your refrigerator's opening. Note the two additional measurements on your paper. Multiply the depth, height and width measurements to obtain the refrigerator's cubic foot measurement.
3 Take the same measurements from the interior of the freezer. Multiply those measurements together to get the cubic foot size of your freezer.
4 Add the cubic foot measurement of the refrigerator interior to the cubic foot measurement of the freezer interior. This gives you the total cubic foot measurement for the refrigerator.
Things You Will Need
  • Tape measure
  • Note paper
APPLIANCE 911
May 19, 2016 | Kenmore Refrigerators
I have a small Roper Top Freezer refrigerator. Twice the freezer coils iced up and I had to defrost them. Each time the freezer came back to a low temp (in the teens to zero) but the refrigerator will not...
Hello James; It sounds like you have a couple of problems. One with the defrost circuit which is made up of the defrost heater, defrost thermostat and the defrost timer. Since it is a Roper it could be any of these items. You can check the heater and thermostat with a multimeter and if you have no resistance on on the heater it is good, the thermostat will have a very low resistance (28 ohms is normal), and it both are good then it is the timer. Now for the main problem, since you say the fan is operational and the cooling tubes are open then I would suggest you run a wire (14 gauge or guitar string) down the drain on the refrigerator side and clear the blockage. I know this doesn't make much sense, but although the fan is pushing air out of the freezer into the refrigerator section (at least somewhat) it has to have air ciculation so either your drain is blocked or the lower cooling tube is blocked preventing a complete circulation path. BTW if you have had cooling tube blockages in the past you can use a strand of wire (14 gauge) hooked over the defrost heater and down the top cooling tube to keep frost from building up.
Sep 26, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer works, it's cool nolt cold in the refrigerator, fan motor doesn;t seem to be working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 19, 2010 | Roper RT14DKX Top Freezer Refrigerator
How big inside (cubic ft.) is the Roper refridgerator
20.9 cubic feet for model # RT21AKXKQ
14 cubic feet for model number RT14BKXKQ05
Jun 07, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Jan 07, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Roper RT12VKX Top Freezer Refrigerator Logo
226 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
