AXIS CD TOWERS
I have replaced the controller, NIC, and the cable. I have LED lights that are a constant green. I can connect via laptop directly to the tower and access the CD's, but when I try to run a ping to my servers it shows as being down, I have link lights and all connections are good. By default the DHCP places an IP address on the Tower, I have disabled this and assigned a static IP address, any Idea why I can't see this server?
    Brigadier General:
  • 6,966 Answers
I am assuming that you are referring to the tower (desktop) as the server while the laptop is the client. While the client can access the server's CD drive, you can not ping the server. A couple of ideas:
1. verify that both server and client belong to the same Workgroup;
2. verify that both server and client have the same Subnet Mask and that their satic IP adds are near each other;
3. Server's firewall settings/configurations does not allow/prevents ping response; and/or
4. the server might be using Zonelab, McAfee Firewall, Microsoft ICF SP2 or some other form of port blocking.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 23, 2008
Wireless light on but no connection
"laptop will connect when plugged in directly just the wireless not working."
Most likely the wireless part of your NIC has failed, they are two separate circuits even if on the same NIC. Easy solution is to get yourself a wirelss USB dongle to plug in to your USB port. Newegg.com has them cheap. If your laptop (you did not specify your model & name) has integrated NIC card on the motherboard you are up a tree. Getting a replacement motherboard for a laptop is almost impossible if it is not under warranty any more and is a couple of years old. My suggestion will work great and is a lot cheaper.
May 14, 2013 | Computers & Internet
How to fix orange blinking light on ethernet
orange blinking on ethernet means that your connection is 10 Mbps and green blinking means 100 Mbps
there's nothing wrong with it
Aug 27, 2012 | Toshiba Satellite M35X-S163 Notebook
Network doesnt work
Go to BIOS, and check if it's "ENABLED"
Mar 18, 2009 | Acer Aspire 5720 Notebook
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Aug 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
AXIS CD TOWER Problems
I'l get back to you, got some stuff to do right now but here are the manuals for your product maybe you can find a solution there untill I get back.
http://www.axis.com/techsup/cdsrv/cd_e100/index.htm
May 22, 2008 | Computers & Internet
AXIS CD TOWERS E100
I am sorry, but this is not really my area of expertise. You could try Ekse or Benimur who are good at networking.
You do not have to rate this post, as I did not really provide a solution.
Axis Cd Tower
I have a very littler idea about your problem,it would be better if you can consult another expert about this.
If you need any other help let me know.
Thanks..
Can't see the Axis over the network
Solid green lights usually mean no activity. Have you checked the Network Card properties and made sure you are using DHCP? Are you plugging into a switch? Is the switch on the same network as your DHCP server? Have you tried different ports on the switch? Also, is the duplex set appropiately?
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
