Building new computer
New mobo, intel d815eea2, got a couple of atx cases and power supply. Pow. sup. is fine, but looking at the front panel assembly harness, to hook it to the J9H3 for the grounds, hdd led, power on, poss. reset, & if the cdrom and/or flop. needs to be hooked. Basicly, with out a preset harness, I am not sure which wire to plug on which pin ! Or do you know where I could get one?
  • 1 more comment
  • bikinibg Pickering
    bikinibg Pickering May 22, 2008
    This is a pic of my board, the pins....are below that ft.panel hook to, I need to know which pin is hooked to which wire !!! And whant is the discription writing on the tip of the wire "connector".
    I have the mobo spec's complete, it does not say which connector goes to which pin...... I am doing this with an older atx case, so I needed some guidence, not a path to no where..... Two cases doesn't have a big enough connector, but the oldest has the harness in separate wiring diag. which you can hook manually.
    bikinibg Pickering May 23, 2008
    Connecting the wrong wires could burn it up!!!!!!!!!!!!!
  • 790 Answers
CHECK THE MOTHERBOARD MANUAL FOR THE EXACT INSTRUCTONS!!!!
Posted on May 22, 2008
  • Kanth raj
    Kanth raj May 22, 2008
    Randomly connect the wires and try booting up !!!
Question I am not sure I know how or who to ask. I am 75 yrs old, very hard of hearing, and am building my third computer. The first two went easily and great. I really am not concerned with having the...
http://downloadmirror.intel.com/15210/eng/D845GVSR_TechProdSpec.pdf
That is a link to the manual of the board...page 56 tells you which pin is which.....now for your case?? Well I have ran into that quite frequently.....and basically you will need to know where the wires are going to the front panel....I have had times where they were not even labeled at all and had to remove the front just to see where each wire went on the front
Aug 06, 2011 | Intel D845GVSR Motherboard
Case switch connected to motherboard is messed up. i need a new switch for the case or the configuration for the pins on the motherboard to be able to use a new case/new switch
The Power On switch is located inside the plastic Power On button assembly.
It is a Momentary Contact Switch, and is named an ATX power on switch.
This ATX Power On switch I have found fits many computers,
http://www.directron.com/atxswitch.html
The plastic front panel of a desktop computer is the Front Panel.
The pin area on the motherboard, that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Tell me the manufacturer name, and Model Number of the computer, or tell me the manufacturer name, and Model Number of the motherboard, and let me see if I can find a Pinout for it's Front Panel header.
(What pins the cables connect to)
Post in a Comment.
Nov 12, 2010 | Computers & Internet
Need to know which style of m b I have is it an atx
The difference between ATX and MicroATX is the size. An ATX board will usually have 6-7 slots to add cards like video, network or sound cards. An ATX board will also usually not have a video port on the board. A MicroATX board will usually have only 3-4 slots to add cards into it, at least one of which being dedicated to AGP or PCI Express Video cards.
To answer your question: That computer uses a MicroATX board. A Micro ATX board will most likely work in any PC Case whereas an ATX board requires an ATX size case (Mid or Full size Tower).
Jun 06, 2010 | eMachines T3508 PC Desktop
Need a new power switch assembly
that is not hard to find at all.u will find them to be almost identical in mist computers.just remove everything like the front panel thru the side panel my friend.
Jun 01, 2010 | NZXT Crafted NEMESIS ELITE...
Intel D815EEA2 mobo won't boot - no clue to why not.
I know, this is a very frustrating situation...
Unfortunately, the only reasonable way to find out what's wrong is to swap components with a reference system, until you found the defective part. I hope you have another P3 system available to swap parts.
I would do it this way:
  • First check that the power button is connected correctly.
  • Swap the memory from the faulty system to the reference system.
  • If ok, put it back into the faulty system and connect the power supply from the reference system (or some other known good one) to the faulty system.
  • If this doensn't help, swap the CPU from the faulty system to the reference system.
  • If the CPU is ok, the motherboard seems to be defective.
Mar 24, 2010 | Intel Desktop Board D815EEA2 Motherboard
Newly built system will not power up!
It seems like you have bad MOBO. I recently ordered all the stuff to build 2 new systems. Built the first one, no power, just like yours. Moved everything to the 2nd MOBO, everything worked. I did a RMA on the DOA MOBO. Got the new one and it fired right up. Sometimes you just get bad stuff.
Please don't forget to rate this solution.
Jun 09, 2009 | Gigabyte GA-8SQ800 Motherboard
On first power up, no video, no sound.
hi
*********** board dead
hope ur smps &ram also ok ......
pl z check motherboard near pc service care.......
Jan 12, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
I need to figure out how to wire the front panel power switch, reset switch etc. to my intel motherboard
look on google for a schematic, or a manual for your mobo model. If you don't have any luck then try just a general search for other motherboard schematics/manuals and you can try their setups.
Dec 19, 2008 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Intel Media Series Intel G33 chipset micro atx no post no boot after crazy fan
make sure you have seated all the cards properly, take them out and reseat them including the ram. Make sure your IDE cables are plugged in properly as well.
Restart the computer and if still no post then yes unfortunatly for you its the mobo =(
Dec 03, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
