AXIS CD TOWER Problems
I have replaced the controller, NIC, and the cable. I have LED lights that are a constant green. I can connect via laptop directly to the tower and access the CD's, but when I try to run a ping to my servers it shows as being down, I have link lights and all connections are good. By default the DHCP places an IP address on the Tower, I have disabled this and assigned a static IP address, any Idea why I can't see this server?
  • Wendy Bauman
    Wendy Bauman May 22, 2008
    The model is a E100, just want to know if there is anything else to troubleshoot on it, I have it in our frame room and it contains CD's that different departments access, can work remotely through a laptop directly connected to it, but can't run my control panel and ping the server.
  • Ekse May 11, 2010
    Can you tell me more about this cd tower, its Axis,, what model? anything else you can tell me about it?
    Thanks.
  • 13,433 Answers
I'l get back to you, got some stuff to do right now but here are the manuals for your product maybe you can find a solution there untill I get back.
http://www.axis.com/techsup/cdsrv/cd_e100/index.htm
Posted on May 22, 2008
3 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: AXIS CD TOWERS E100
I am sorry, but this is not really my area of expertise. You could try Ekse or Benimur who are good at networking.
You do not have to rate this post, as I did not really provide a solution.
Benimur
  • 6966 Answers
I am assuming that you are referring to the tower (desktop) as the server while the laptop is the client. While the client can access the server's CD drive, you can not ping the server. A couple of ideas:
1. verify that both server and client belong to the same Workgroup;
2. verify that both server and client have the same Subnet Mask and that their satic IP adds are near each other;
3. Server's firewall settings/configurations does not allow/prevents ping response; and/or
4. the server might be using Zonelab, McAfee Firewall, Microsoft ICF SP2 or some other form of port blocking.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 23, 2008
How to fix orange blinking light on ethernet
orange blinking on ethernet means that your connection is 10 Mbps and green blinking means 100 Mbps
there's nothing wrong with it
Aug 27, 2012 | Toshiba Satellite M35X-S163 Notebook
Acer Aspire M1640 PC monitor 'no signal', tower non-responsive.
i found the same problem (can't load BioS) but we are not alone as you can see on web about M1640 and M1641 it's very popular defect
I made various test:
cpu (pentiun e2180) pass the test mounted on another PC.
I removed the two ram and replace with other ,result nothing (Pc power on but can't load the BIoS).
Some of this Acer model have this motherboard crash
look also here
http://www.tomshw.it/forum/schede-madre-e-ram/129267-scheda-madre-non-da-segnali-di-vita-microstar-n1996.html
http://www.tomshardware.co.uk/forum/271665-12-motherboard-problems-m1640
http://www.fixya.com/search/p954810-acer_aspire_m1640_refurbished_intel_desk/acer_aspire_m1640_fast_ddr2
http://www.tomshardware.co.uk/forum/270660-12-acer-motherboard-sak09-replacement
Change the MotheBoard
Mar 10, 2010 | Acer Aspire M1640 Refurbished Intel...
How do i hook it up to the internet. i have been giving a gateway model fmn400c and icant figure out what hooks it up to the internet... i currently have a laptop hooked up to the internet via cable...
Is there a NIC in the Gateway? A place to plug in a cat 5 cable? If yes, there is your answer. You will need a place to plug in the other end ... if you dont have a router, you will need one. I recommend LinkSys routers though there are other brands.
If you have no NIC, get a PCI based NIC at the Big Box Store. They can tell you how to put it in or for a small fee, they will do it for you.
Mar 09, 2010 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
4100 Light flash no connection
*if the DSL light on your modem is blinking..
TRY: using different filters// check physical connection
IF: not resolved call ISP for a trouble ticket for their line department
*if all the lights constantly blinks
DO: purchase new modem, maybe deffective already or check if modem still under warranty so provider can replace it
NOTE: plug 4100 modem directly to the back of the computer tower without the linksys router and check if light status still the same...
HOW: cable connected from back of modem shud be plug in directly to port at the back of PC tower.. completly remove linksys and turn linksys off..
Jul 16, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
AXIS CD TOWERS
May 22, 2008 | Computers & Internet
AXIS CD TOWERS E100
Axis Cd Tower
I have a very littler idea about your problem,it would be better if you can consult another expert about this.
If you need any other help let me know.
Thanks..
Can't see the Axis over the network
Solid green lights usually mean no activity. Have you checked the Network Card properties and made sure you are using DHCP? Are you plugging into a switch? Is the switch on the same network as your DHCP server? Have you tried different ports on the switch? Also, is the duplex set appropiately?
Connected but can't open web pages
might be the NIC card not properly installed >or may be its not working first check the cable weather its connected properly and check weather the light on the back of teh computer its on and color green>and if its not then contact ur computer vendor probally u need to install the soft ware with teh help of him rte me solved if its helps
Nov 23, 2007 | Zyxel P660HW-D1 Router
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
