Question about Compaq Presario 700 470024-192 Notebook
Power issue I have a Compaq Presario and while I was working on battery the charge went low and shut down the computer. I charged the battery and now when I try to turn on the computer the computer starts to turn on the shuts off after 3 to 4 seconds, then 5 seconds later it tries to turn on again. It stays in this cycle until I pull the battery. I have tried just using the power supply with out the battery and with the battery and the same cycle happens.
  • 2 more comments
  • jstar90 May 23, 2008
    This did not work. There is no disc in the drive and I kept tapping the F8 key and the computer just keeps cycling on for 3 seconds and off for 10 seconds
    Got a little further, by pressing f10 f11 the computer stays on, but you don't see anything on the screen.
  • jstar90 May 24, 2008
    How do I get my disc driver to open in this state to be able to reinstall windows?
    Thanks for all your help. I will take it to a tec.
  • 207 Answers
Plz check if there is any disc in the drive?
if not this time the system restart keep tapping on f 8
and go to safe mode type msconfig in run clk ok
new win will *** up go to startup tab down at bottom disable all
apply ok restart teh computer clk on the chk box dont show this mesg again once the computer will boot let me know if teh thing doesnt work
Posted on May 22, 2008
  • 1 more comment
  • varun grover May 23, 2008
    ok pls try to boot the computer in bios f10 f 11 ..even if tht thing doesnt work take it to repair center cause it might be a prob be wd a motherboard
  • varun grover May 24, 2008
    ur windwos are corrupteg needs to reinstall then
    try this boot the compter till where ever it goes wait for 5 mins and then see if u r able to open the door of the disc or not!!! if not then u might need to see the face of tech
I have a Compaq Presario R3000 with Windows XP OS. Until recently it had been working fine. Suddenly, the power went off while still connected to the AC Supply and the Laptop just went off. The battery...
1. Remove battery from the laptop. 2. Unplug the power cord from the computer. 3. Let the computer sit for a few min. 4. Leave battery out. 5. Connect power adapter to computer 6. Push power button to turn computer on. 7. If computer powers on shut down again, and put battery back in. 8. Push power button to turn computer back on (at this point battery and power adapter should be connected to the computer)
If computer powers on with power adapter with the battery out. You are having a battery issue. You would want to look into replacing the battery. If computer does not power on with just the power adapter. You are most likely having a power issue. Depending on how old the laptop is. You will either want to contact the manufacturer. Or take the computer to a computer repair shop, or consider replacing the laptop.
May 31, 2011 | Compaq Presario R3000 Notebook
Shuts off unxepecedly
First thought when this happens is an accumulation of dust in the heat sink inside the computer. If the computer cannot cool itself, then it will shutdown. This normally happens within a few minutes of powering up the computer.
Now if there is a power issues, if the battery is not charging properly, that could be another issue if it shuts down, especially if it is running on battery power.
Now, if it does not charge, then it could be the cord.
Rare, but not out of the question, the power jack where the power cord plugs into the laptop may be at fault.
Good luck
Dec 20, 2009 | HP Compaq Presario F750US
Compaq presario V2000 doesn't start
you might have shot out your battery because if electrical curent is goging in to the computer (te orange light is going on) but the computer wont turn on it might be a problem with your battey
please rate
May 30, 2009 | HP Compaq Presario V2000 Notebook
My compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Apr 03, 2009 | HP Compaq Presario C500t Notebook
Takes 4 days to charge battery and dim display
you battery has become weak check and replace the battery
Nov 27, 2008 | Compaq Presario M2000 Notebook
Compaq Presario needed a new battery was installed labtop will not charge up!
When you install a new battery and remove a battery always make sure the laptop is completely shut off and have the power cord removed so that you avoid any possible power surge.
Batteries generally don't last much longer than a year and I have found removing the power cord or battery when it is off to be a good practice.
Before you charge a battery make sure it is run most all the way down. Recharging a battery when it is not run down can give it a memory and you may only be able to charge it up to the point you started charging it.
Anyway, if the computer won't charge a new battery then you could have a bad motherboard. To be sure try another battery.
Sep 09, 2008 | Compaq Presario Notebook
Compaq Presario X1000 power issues
Unassemble the fan and see if there is a lot of dirt and dust in there. If the fan is NOT working you need to fix that issue before you do anything else. Does the computer randomly shut down ?
Aug 27, 2008 | Compaq Presario X1000 Notebook
Wont charge
It could be that your battery is defective/worn out. If the computer just shuts off immediately (doesnt try to hibernate/standby) then you're likely looking at replacing the battery. They can suddenly do things like this if a cell shorts out in the battery or due to common wear. But first, here are a couple of things you can try.
1. Try reseating the battery (pull it out and put it back in). Sometimes something that simple can fix the problem.
2. Try to calibrate the battery. Your computer may come with instructions on how to do this, but if not you can do it manually. Turn the computer on but go into BIOS (press F10 at the compaq logo screen). Don't load your operating system
Unplug your computer. If it turns off at this point, your battery is already toasted. Replace it.
If the computer keeps running, let it go until it finally shuts off due to battery drain. Then plug it back in and let it recharge completely. This will let the microchip in the battery learn its charge potential and may allow you to get more life out of it.
Note: Calibrating these batteries is good practice but it shouldn't be done very often. If your calibration doesn't work after 1 or 2 tries, you probably still are looking at a dead battery.
Apr 23, 2008 | Compaq Presario R3000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
90 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
