2002 Mercury Grand Marquis Logo
Posted on Sep 25, 2010
2002 Mercury Grand Marquis. Initially car would not hold an idle. It would stall after starting. Changed the IAC. Replacement component started making a "howling" sound while engine was running, especially at idle. Changed IAC again, same condition only worse. Is there some calibration, or further setup beyond simple plug and play with the replacement IAC?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
377
Points
On 2002 grand marquis the switch for the adjustable mirrors does not work. Is this a fuse or component problem
Usually the switch goes bad, not a fuse...but check for all blown fuses,...if all are working, then the old a vehicle needs a new part (eBay) or junkyard selection part from the same year vehicle
1helpful
I have a 1998 Mercury Grand Marquis rough idle, smelling gas first few minutes after I start my car. My car is also flashing engine light sporadically and losing acceleration.I recently changed spark...
flashing light most always means missfire.
could even be crossed wires.to the plugs.
you really need a code reader and find the trouble code .
but in the mean time make sure the firing order is correct.
good luck .gary
Recently changed plugs on my marquis and it started stalling at idle and during acceleration. I thought maybe fuel filter so changed it. Problem still exists. Any ideas what the problem might be?
Is it possible that while changing the plugs you disconnected a vacuum line accidentally, or bumped a line that may have caused a crack in a dryed out vacuum line?
Starts with acceleration once warm starts fine already changed maf sensor.
Question isn't exactly clear. If you mean that you have to press the accelerator to get the car to start, you probably need to replace the Idle AIr Control Valve (IAC). Other possible causes include a fault throttle sensor or a vacuum leak.
1helpful
Won't start while hot, wait an hour fires right up and runs / idles /drives smooth
FORD: 1995-96 CONTOUR, CROWN VICTORIA, ESCORT, TAURUS, THUNDERBIRD
1996 MUSTANG LINCOLN-MERCURY: 1995-96 CONTINENTAL, COUGAR, GRAND MARQUIS, MARK VIII, MYSTIQUE, SABLE, TOWN CAR, TRACER LIGHT TRUCK: 1995-96 AEROSTAR, BRONCO, ECONOLINE, F-150-350 SERIES, RANGER, WINDSTAR
1996 EXPLORER This TSB article is being republished in its entirety to include the 1995 4.6L Thunderbird/Cougar. ISSUE: After a 1-4 hour engine soak time, long crank times and/or long crank to start followed by a stall may occur on some vehicles. No further stalling or rough idle will occur after the engine is running. The long crank and/or stall may be due to the Idle Air Control (IAC) Valve sticking.
ACTION: Replace the IAC Valve with a revised IAC Valve if no Diagnostic Trouble Codes (DTCs) are present. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
  1. Perform normal diagnostics and correct any DTCs as required by referring to the appropriate year Powertrain Control/Emissions Diagnosis (PC/ED) Service Manual.
  2. If no codes are present, replace the IAC Valve by referring to the appropriate model/year Service Manual, Section 03-14. Refer to the following Idle Air Control Valve Application Chart for proper IAC usage.
    IDLE AIR CONTROL VALVE APPLICATION CHART Model Year Vehicle Engine Revised Part Number PASSENGER CARS 1995 Escort/Tracer 1.9L F5DZ-9F715-BA 1996 Escort/Tracer 1.9L F6CZ-9F715-BB 1995 Contour/Mystique 2.5L F5RZ-9F715-AB 1996 Contour/Mystique 2.5L F6RZ-9F715-AA 1996 Taurus/Sable 3.0L 4-Valve F5DZ-9F715-DA 1995 Taurus/Sable 3.0L 2-Valve F5DZ-9F715-EA 1996 Taurus/Sable 3.0L 2-Valve F6DZ-9F715-DA 1995 Taurus SHO 3.2L F6DZ-9F715-CA 1996 Taurus SHO 3.4L F6LZ-9F715-AC 1995 Taurus/Sable 3.8L F68Z-9F715-EA 1995 Crown Victoria/Grand Marquis/Town Car 4.6L 2-Valve F5PZ-9F715-AA 1996 Crown Victoria/Grand Marquis/Town Car/Mustang 4.6L 2-Valve F6AZ-9F715-EB 1996 Mustang 4.6L 4-Valve F65Z-9F715-BC 1995-96 Continental 4.6L 4-Valve F5OZ-9F715-AB 1995 Mark VIII 4.6L 4-Valve F3LZ-9F715-AA 1996 Mark VIII 4.6L 4-Valve F6LZ-9F715-AC 1995 Thunderbird/Cougar 4.6L 2-Valve F5PZ-9F715-AA 1996 Thunderbird/Cougar 4.6L 2-Valve F6AZ-9F715-EB LIGHT TRUCKS 1995-96 Ranger 2.3L F5OZ-9F715-AB 1995-96 Ranger 3.0L F67Z-9F715-AA 1995 Aerostar 3.0L F68Z-9F715-DA 1996 Aerostar 3.0L F69Z-9F715-AA 1995-96 Windstar 3.0L F68Z-9F715-DA 1995 Windstar 3.8L F68Z-9F715-EA 1996 Windstar 3.8L F68Z-9F715-CB 1995-96 Econoline/F-150-350 Series/Bronco 4.9L F68Z-9F715-EA 1996 Explorer 5.0L F67Z-9F715-BA
96 mercury loses power going up a steep grade
It may be a leaky injector. The injector is connected to the bank. 1 of 2 fuel rails.
Need electronic control unit for 1995 grand marquis
There is a throttle position sensor and ther is also an iac (idle air control) module. The iac failure usually results in a very high idle
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
