Wireless laptop failure
Hi, you wrote me a solution to my laptop problem. It was helpful because thats is exactly what i would normally do if the wireless system is not working however on this occasion when i went to do that the little computer that i would normally click on is not there at all anymore!
  • Anonymous May 23, 2008
    i have wirelss but when im connected to wireless it doesnt look for the pages..why is that?
    Scholar:
  • 144 Answers
To look for wireless icon on windows XP start by clicking
start-->Settings-->Network Connections
here you shoud able to see wireless network connection
Double click on wirless network connection and below you
would see "show icon in...." and also " notify me...". Check
on this 2 box and click apply.Next time you'll be able to see this icon again.
goodluck,takecare.
Posted on May 24, 2008
Wireless does not work on asus eee pc 900
What exactly is the problem? Wireless not working is not very descriptive of your problem because there are many things that come into play in order to have wireless.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 18, 2012 | ASUS Eee PC 900 PC Notebook
Internet goes off every 10-20 minutes - unplug router and it comes back on only to go off in a few minutes; as a result, host computer and laptop set up via wireless connection continue to go off
You may have some setting incorrect in your wireless router. What I would suggest that you do is reset the router and adjust your settings correctly.
This should take no more than 10 minutes and you'll be as good as new.
Here is a Tip I wrote up on how to do exactly that.
http://www.fixya.com/support/r8641009-wireless_network_reset_setup_linksys
Magoo
Mar 13, 2011 | Linksys Wireless-G Broadband Router
Hi i bought the smc wireless router and i tries to connect it but i couldnt figure out how to connect it because i have a laptop and my internet is connected from my modem to my laptop but i cant seem to...
I'm unsure of the exact part number here but using the model number I checked the manual. This looks like it's just an access point which extends a current network you have. If you only have your laptop, this device and your internet modem it may not give you the wireless connectivity you're looking for. On a normal setup you would plug your modem into a router, plug your laptop into the router and set it up with all your DSL/Cable connection information as well as wireless on/off. You can then unplug from the router and continue life. with this one it's only connecting to an existing setup (another router or another wireless network) and extending it.
If you are looking for a solution to give you a router that connects to your modem and gives you wireless or adding multiple devices on a single connection I would recommend returning this and getting an all-in-one router such as this: http://homestore.cisco.com/en-us/Routers/Linksys-E1000-Wirelessn-router_stcVVproductId97826160VVcatId551966VVviewprod.htm?icid=linksys-specs-e1000-learnmore-btn&src2=linksys-specs-e1000-learnmore-btn
Mar 07, 2011 | SMC EZ Connect g SMCWEBT-G
I am trying to use dell 5150 laptop wireless with a new verizon wifi
Hi, I understood that you are trying to use dell laptop with verizon wifi. but may i know what exactly is the issue that you are facing ?
I'll be more than happy to help with more explanation :)
Nov 02, 2010 | Dell Inspiron 5150 Notebook
Hi, I have acer acpire, model 5534. wi fi wont connect to wireless network. What can cause this problem thanks
Do you see a wireless or network icon in the lower right of the screen, next to your clock? Can you view a list of available wireless networks?
If so and you can see your laptop trying to make a connection on your screen and it just fails to connect, it's likely you've typed in your wireless key wrong.
If not, it's possible you've hit a wireless button or switch and shut your wireless off. On many laptops, there's a switch on the front or sides of the laptop that'll switch wireless on or off. On others, you'll have to look for a colored Fn (function) key on your keyboard. You may have to hold that Fn key and search for a wireless icon on one of other key's that's the same color (usually blue) as your Fn key.
Unfortunatly, I can't find any good pictures of your laptop to tell you exactly where it is. But let me know if this helps!
Matt Audette
www.verical.com
Feb 01, 2010 | Acer Computers & Internet
My notebook does not start any more. don't know what to do. when turned on, green lights up in from switching on and thats about it. nothing else. i've checked memory and hard disc, seems to be fine. is...
Make sure there is nothing on the screen and there is no activity from the hard drive. Possible cause: 1. Memory failure.
2. Motherboard
failure.
3. CPU failure.
Possible troubleshooting steps and repair solution: Test the laptop with an external monitor and confirm that there is no video on the external screen.
If the laptop powers on to a blank black screen, check the laptop memory first. It’s very likely that you have memory related failure.
Try reconnecting the memory module, maybe it’s not making good contact with the slot.
Try moving the memory module into another slot, maybe the first slot failed.
If you have two memory modules installed in your laptop, remove them one by one. One of the memory modules could be bad (it’s very unlikely that both modules failed at the same time). Test the laptop with each module separately, try different slots.
If you have only one memory module installed, try replacing it with a new memory.
If reconnecting, replacing memory modules doesn’t help, most likely this is motherboard failure. Replace the motherboard.
CPU failures are very rare but it happens once in a while. From my experience, you can get one or two failed CPUs on a hundred failed motherboards.
Nov 08, 2009 | ASUS Eee 1000H Notebook
HP pavilion laptop dv2120us wireless nic intermittent failure
I think you have a suspect hard drive on your laptop. It is slowly failing. Hopefully you have got the Recovery CD/DVD for it. Not sure what OS you are running. I suppose it will be Vista. You can download disk test utility Seatools from Seagate website and it will give you an indication of the state of your drive. I think this model of HP laptop used a very cheap generic brand disk drive. Best to replace with Seagate or WD of same capacity as your present one. It will be hard to get data back if you do not have backups. Hope this helps.
Nov 05, 2009 | HP Pavilion dv2120us Notebook
Wireless switch still red, wireless assistant not available
Two questions:
Q1: Do any other switches/touch buttons work? If not then follow the procedure below:
1. turn off computer 2. Remove battery and power plug 3. hold down the power button for 20 secs 4. reattach battery and power plug 5. Turn on laptop. 6. All buttons will work including the wireless
Q2: Do you see the HP Wireless Assistant icon in your system tray? If not then go to start menu and search for the above.
Once you locate it open the program and check if your installed wireless device is on or turned off. In case of the latter, Turn it on from the action list. Once your device is on the touch button will work.
Sep 10, 2009 | HP Pavilion dv9000z Notebook
Toshiba (PA3070U-1MPC) 802.11b Wireless Adapter
Usually Toshiba WEB site would have the driver, you normally go to their download page, enter your laptop model and device etc.
Failing that there are a couple of WEB site that have a large collection of drivers, you need to know the exact make and model of your device. TRY
www.driverguide.com
www.driverscollection.com
Jun 10, 2008 | Toshiba (PA3070U-1MPC) 802.11b Wireless...
Computers & Internet Logo
236 people viewed this question
David Payne
David Payne
