Question about HP DeskJet 1280 InkJet Printer
Hp 1280 how do you clean
I am printing on card but sometimes it doesn't pick it up very well how can i clean the rollers etc, i am working with a mac!
thanks
Kt
  • 300 Answers
Isopropyl, failing that nail vanish remover (but don't get it on the plastics)
Posted on May 22, 2008
Our printer HP 1280 we can print 1 page only then trouble will occur paper jam even theres no paper clog inside the roller..
clean your printer from inside carefully and use orginal HP inks then you will not face any problem
Feb 19, 2012 | HP Deskjet 1280
Hp officejet 1280 is picking too many papers once and it jams
The intake to the paper could have an alignment issue as it is possible that two or more sheets get into the slot.
so check if the printing paper is of the correct grade and is not lower than the recommended thickness.
A paper of low thickness can cramp into the slot and jam.
Also if the paper has a tendency of sticking this can happen , check if there is moisture on the sheets.
Finally clean the intake section, the inner rollers and the pick up roller. the alignment of the rollers are to be checked.
Jul 29, 2011 | Computers & Internet
I have hp 1280 A3 Inkjet printer . When I give print it pick up paper and out the blank paper without printing . a4 printing is ok. But A3 Is majour problem
May 20, 2010 | HP DeskJet 1280 InkJet Printer
My HP 1280 printer does print black and white text
Could it just be that the black cartridge has run out? If not, try and clean the print heads. You should be able to do this in the printer options in Windows. It is more than likle that the black nozzle is blocked.
Dec 13, 2009 | HP DeskJet 1280 InkJet Printer
Printer sometimes will not print must push paper button several times.
Hello sir; Try to clean up paper pick up roller with alcohal, otherwise , you have to replace paper pick up roller.
Nov 06, 2009 | HP DeskJet 722c InkJet Printer
Printer won't pick up the paper in the tray to print. Keep getting out of paper message
First check if the feed rollers are 'Slick" with paper dust, if they are ,clean then with 409 on a cloth rag, and scrub till u dont see the white paper dust on the rollers, let the rollers dry, then reset the printer, by turning it off. then turn it back on ,reinstall the paper and begin printing again.
Jul 15, 2009 | Office Equipment & Supplies
I a having problems printing business cards on my HP PSC 1210V
The cards are likely slipping on the pick up. I assume you are using tray 1 not tray 2. you can try cleaning the pick roller use water and wipe. If thie condition improves you have found the problem and should replace or have the roller replaced.
Mar 31, 2009 | HP LaserJet 1320 Printer
Hp deskjet 1280
seems like the pick up roller and seperation pad are dirty or worn.try cleaning them with nail polish remover. the roller is located at the bottom of the printer where the leading edge of the paper is the seperation pad sits under the pick up roller.
Nov 27, 2008 | HP DeskJet 1280 InkJet Printer
Print
hmmm..ok..power down completely..
unhook from computer
press button on power panel down..hold it for ten seconds, while plugging in power cable again..
system should go through start up sequence
then try a test page..
if not , time for factory service.
Aug 06, 2008 | HP DeskJet 1280 InkJet Printer
HP DeskJet 1280 InkJet Printer Logo
145 people viewed this question
Ben Johnson
