Question about Klein Electronics Blackbox-V 2-Way Radio
Programming I am using the usb to 2 pin connector to program. I have loaded the drivers and when i hook up the cable and turn the radio on windows say unknown device and or malfuction.
Manual or driver PL2303HXD or PL2303TA indesparete need of both. Scott @ prariedog60@yahoo.com. This is a uv5r bt baofeng. The drivers that come on the CD are PL2303 and will not work on windows 8.1
hi i have the same problem and i buy a other cable whith extra dierent pins (connectors) thats Works on my computer win. 8. I try to up load the program and i cant sent to me an e mail feliciano132003 at Yahoo dot com and i sent the disk of the cable to you try that
Mar 14, 2015 | Baofeng UV-5RA Dual Band Transceiver
Uv-5ra programming
The problem I found with the programming software was with the driver that is included with the software. Google Baofeng software driver and follow the instructions on how to load as well as how to remove the non-working driver. If you don't remove the original driver, windows will revert back to the original instead of using the new driver. Good Luck!
Jan 15, 2014 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
Connecting to the computer
You should have received a cable with your XL-6000 that allows it to communicate with your computer. The one that came with my machine has a pin type connector on both ends and it's known as a null serial port connector. I had to purchase another cable because the pin connector would not work with my USB ports on my laptop. I ordered one online and it came with a CD (driver) that you have to load to your computer to make it work. Another thing was that my newer version of Windows (7) would not run the conversion software that came with the sewing machine. There is a feature in Windows 7 that allows you to run software made for previous versions of Windows. Go go Control Panel>Programs>Programs and Features>Run software made for previous versions of Windows. Hope this helps.
Apr 23, 2013 | Singer Quantum XL-6000 Computerized Sewing...
How to reset canon ip2700
WindowsThe printer driver you no longer use can be deleted.When deleting the printer driver, first exit all programs that are running. The procedure to delete the unnecessary printer driver is as follows:
  • When There is an Uninstaller
1. Start the uninstaller - If you are using Windows 7, Windows Vista, select the Start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller.- If you are using Windows XP, select the start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller. - If you are using Windows 2000, select the Start menu -> Programs -> "Your model name" -> Printer Driver Uninstaller.
Restart the Computer and perform the following:Windows
  • If you connect the printer via USB cable before installing the software:
For Windows 7:(1) Remove the USB cable connected to your computer.(2) Proceed to 1.
For Windows Vista/Windows XP/Windows 2000:The above dialog box may appear.(1) Remove the USB cable connected to your computer.If the dialog box closes, proceed to 1.(2) Click Cancel.(3) Proceed to 1.
  • Easy-WebPrint EX:
If you are using Internet Explorer 7 or later, you can use the Web print software Easy-WebPrint EX. An internet connection is required for installation.
1. g0069739.pngPress the ON button (A) to TURN OFF THE PRINTER.Operating noise may continue for up to 25 seconds until the printer turns off.
2. g0069740.pngTurn on the computer, then insert the Setup CD-ROM into the CD-ROM drive.If you are using Windows, the setup program starts automatically.
Mar 31, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Is there any way to interace with USB
You will need 3 items to interface your Wizard with a USB port.
1. A generic USB to RS-232 adapter cable (with 9-pin serial connector, to match the connector on the OZ-730 interface cable).
2. A USB to RS-232 driver for the above cable. (If you have Windows XP: HL-340.EXE, contained in 111.rar, which can be downloaded from www.usbserialdrivers.com. If you have another version of Windows, or if you have Linux, you will have to consult the documentation on www.usbserialdrivers.com to find the correct driver.
3. Software to communicate with the Wizard. You should be able to use the software that came with it, or purchase RuppLynx, or download Microsoft ActiveSync or a similar free program.
I used a cable I purchased on ebay, the HL-340.EXE driver installer, and RuppLynx software to connect an OZ-730, an OZ-570, and a Zaurus 5800 to my Windows XP laptop without any problem.
Nov 13, 2010 | Sharp Wizard OZ-730
I want to know where the red,yellow,blue, green,,white,and black wires go?
red and black are power and ground, blue and white are gps output signal connect those to 9 pin connector pins 2 and 5 and get a 9 pin(serial) cable to usb adapter for input to a laptop, charting or mapping program and you are good to go. just make sure if you are using xp to wait until the mapping program is running and searching for gps signal before you connect the serial or usb because windows thinks the signal is from a mouse and the cursor will turn into a raging crackhead jumping all over the screen and randomly clicking on whatever it touches.
Jun 17, 2010 | Furuno GP31 GPS Receiver
What pins to short out on Bendix King EPH to program?
lay the handheld on its back, the two pins closest to the table top and bottom are the two pins, use a dime or paperclip works best.
Jun 08, 2009 | Bendix King LPH, LPA, LPX, EPH Compatible...
Programing a uniden BC246T
Not all programming software supports usb. Either find software that supports usb or you can buy add on cards to your pc that will give you a serial port. Hope this helps
Jan 26, 2009 | Uniden BC246T Handheld Scanner
I dont know how to hook up my lexmark X1150 printrio to my Dell Windows Xp
If the lexmark has a usb, use a usb cord to the Dell. If it has a centronics connector (old), U can still get a cord online. If the question is software, then uninstall the printer software using the control panel - add/remove programs, assuming it didn't work and re U R here. Leave the printer connected. Use the control panel - system - hardware - devices and uninstall the printer. Reboot. When the system detects the printer, use the printer cd to load only the driver. Try it and if ok, than U can load the printer programs.
BigBiggs
Jun 15, 2008 | Computers & Internet
Pansat 2500a FTA receiver
I would suggest to go here to get a lot more info on how to program this receiver.
Feb 22, 2008 | Televison & Video
Klein Electronics Blackbox-V 2-Way Radio Logo
62 people viewed this question
Top Klein Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Klein Radio Communication Expert? Answer questions, earn points and help others
