The CRTs have coolant in them, they also have a history of leaking the coolant onto the circuit boards causing the set to shut down. If you need more help let me know.
you would have to look at the circuit boards for evidence of a thick, pasty substance on the components.you would have to look at the circuit boards for evidence of a thick, pasty substance on the components.
You can't post conmments that contain an email address.
you either have leaky capacitors near the voltage regulators, cooling fluid leaking on the boards, and/or bad solder connections on the yoke plugs. this model is known for all 3 problems, but you probably need a qualified tv repairman to fix this right.
i have a 50in mitsubishi tv model vs5046 the screen protector is crack the tv works fine but need to know where can i purchase a protector or its there a number. also how much will this cost.
Good Day, rmorales;
Does the buttons on the front panel work properly? I would suspect a bad button assembly.
I hope this helped, good luck, big IRISH.
This model is known for the front control panel going bad. You could unplug it, control panel cable, from the front of TV, by removing the speaker grill, and just use the remote.
Push the menu and inputs buttons on the set in both together and hold for 8 seconds this should make the led flash a two digit code. Let me know what happens after doing this test.
how I know if this is the problem causes my TV shut down?
thanks!
