Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
How do I replace Fan moter of Admiral Refgirator model LSD2615HEZ?
Admiral Refg. Model No LSD2615HEZ is having problems on refgiration side. Freezor is working fine but refgiration side its not cooling. Can you please help ?
  • krisyeargain Aug 20, 2008
    2 y/o frig. Freezer is working fine, refrigerator not cooling. Please help.
  • nikkitorn Sep 26, 2008
    Same thing happening to my 2 yr. old fridge. Someone said it could be the defrost timer is bad. Anyone know how to change? If you unplug it for 24 hrs. then plug it back in, it helps, but only for a few days.
Lower freezer setting so more air can travel to refrig
Posted on Sep 16, 2008
I have an Admiral side by side model LSD2615HEZ that is not cooling. I can hear the hum of the condenser, but do not hear fans kicking on when I turn the temp gauge from 0 to 9. I don't hear a click or...
Do you hear the thermostat control clicking off and on if so turn on set about half way and remove cover from back and see or hear if the compressor and motor are running if not you need to replace the starting components go to a appliance store and buy a 3 in 1 kit and follow the diagram for installation make sure you disconnect the power before working on it. good luck and please leave me feedback so I know it works.
Feb 04, 2015 | Admiral 26 cu. ft. Side-By-Side...
Hi, I have privilege refgirator in white color simple option. On above of the beside the button there is a word written S what does it mean? And the refgirator is very cold and all staff in refgirator...
This sounds like a fault. Could be caused by freezer not defrosting . Had a similar fault in a fridge and it was the condenser that had died. I only found this out when the fridge repairman inspected the fridge. The cost of repair was not worth getting it repaired and I purchased a new fridge. You may be lucky and not have a major component fault.
Jul 05, 2014 | Refrigerators
My Admiral LSD2615HEZ freezer is icing up? The freezer temperature setting is set between 4 & 5 and the water dispenser and ice maker are working properly. What might be the cause and what are the...
Check the water pan underneath, dump if necessary. Clean up any dust, etc. Reset to normal temp and do not open door for 24 hrs. If this doe not work check compressor / condensor
Aug 13, 2013 | Admiral 26 cu. ft. Side-By-Side...
Admiral Refrugerator model LSD2615HEZ. Unit will not deforst, having to manualy do it. I do not see a coil heater, does this unit have hot gas by-pass?
Many different things can cause a defrost problem, it can be a thermostat, defrost heater or a control timer issue. I suggest you hire an expert to save yourself time and grief.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | Admiral 26 cu. ft. Side-By-Side...
My admiral side by side refrigerator (model #: LSD2615HEZ) is making a buzzing noise that clicks on and off periodically. It sounds like it's trying to start something and then shorts out after about...
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one.
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 15, 2011 | Admiral 26 cu. ft. Side-By-Side...
Admiral refridgerator model lsd2615hez is making a buzzing sound every 2 minutes. The buzzing sound lasts 20 seconds and everything in the freezer is melting. What could be causing this?
what you are hearing is the compresor trying to start . and can not so the over load is shutting down . and when it cools it will try again .. you need to replace the starting device on the compressor .cost about 80.00 parts .. most models . some are more. and the melting is caused by no comp runing .. this is a very common problem .. hope this helps mm feed back pls .
Feb 01, 2011 | Admiral 26 cu. ft. Side-By-Side...
The handle on my refrigerator door (Admiral side by side model LSD2615HEZ) is loose. How do you tighten the handle?
There is a plastic card that came with the refrigerator. Pull the handle towards you and slide the card between the door and handle on the top side of the lower handle. Slide the card until it stops, I believe its 11/16". Next slide the handle upward to release it. It may take some force to release the handle. Once its removed, you will see a bracket on the handle. In my case, the screws were loose. Tighten the screws and replace the handle and its fixed. To reinstall the handle, line up the handle with the brackets on the door. Slide down until you here a click that indicates that the handle is installed properly.
Dec 30, 2009 | Refrigerators
ADMIRAL LSD2615HEZ
Pls.check the unit if does have a low and high preasure switch,posible the system is in the low preasure that switch to cut off the unit.check system preasure,if low preasure found,you need to recharge the system.
Nov 19, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
225 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
