Question about HP PSC 1350 All-In-One Thermal Printer
White lines in print--looks like pinstripes
On my HP1350 all in one desk jetprinter, the ink cartridges are full but white streaks persist when printing photos. I've done an alignment 5 times in an attempt to correct, ,cleaned the ink cartridges and wiped down as much of the inside of the machine as I can from the outside--to no avail.
I asked the technician at Staples what he thought and he thought it was the ink cartridge. since I was using 3in1 cartridges and it was expensive to buy two; (1) Black with pale magenta and blue plus (2)red blue and yellow,we bought a new printer that uses one colour only cartidges so we can replace one colour at a time and also use a pale blue and pale magenta to get better reproductions. for a little more than double the price we bought an Hp printer Photosmart C7280 on sale with single cartridges. It will pay off, They are a fraction of the cost of 3in1 colours.
Posted on May 24, 2008
Canon Pixma iP6000D prints white streaks thru the words
Run a self clean on the printer a jet may be clogged. print a test page to see if problem persists. If ink is low put a piece of electrical tape over the sensor of the ink cartridge and try again.
Hope this helps!
Aug 13, 2012 | Canon Pixma iP6000D InkJet Photo Printer
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
Color wont print
It could be that your cartridge needs cleaning. Open the Lexmark Solution Center. Click Start, Programs (Windows XP: All programs), Lexmark Z600 Series. Click the Maintenance tab. Under Select a maintenance tool, select Clean to fix horizontal streaks. Click Print. If the printed bars in one color fade on either side of the page or are shorter than the other bars, the cartridge is running low on ink of that particular color. If there are thin lines running through the bars or if the diagonal lines at the bottom are broken, the cartridge may need cleaning. Follow these instructions:
  1. Remove the problematic cartridge or cartridges from the printer.
  2. Take a warm damp paper towel and set the ink cartridge right-side-up on it so that the ink nozzles are against the towel.
  3. Hold the cartridge in this position for about 15 seconds.
  4. Wipe the printhead (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
  5. Next, dab the cartridge on the towel to make sure that the ink is flowing.
  6. Use a clean part of your dry paper towel to make sure that the cartridges are dry and then snap them back into the printer.
  7. Select Old Cartridge install in the software.
  8. Repeat the Clean Nozzle Page test one more time.
  9. If the problem persists, you may need to replace the cartridge.
Source: How to Clean the Cartridges of the Lexmark Z615 Color Jetprinter in Windows
May 21, 2011 | Lexmark Z611 InkJet Photo Printer
Streaking effect during printing Officejet 7130
As you have replaced the both cartridges and still the issue persists, then this is a hardware issue with the unit. Please repair your printer.
:) Dr Tony
Apr 14, 2010 | HP Officejet 7130 All-In-One InkJet...
Every fifth line has a white streak through the
I would try using something like rubber renew on the pickup rollers and make sure that the paper is being fed correctly. If this is happening then start looking at the ink.
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Some printers will let you re-run a cleaning utility from their system menu or the computer printer properties. Keep in mind too that some printers will not print correctly, even with full ink, if the exact type of ink it expects you to have is not installed. If all else fails change out the ink, but double check that the ink is correct against the manual or written instructions inside the printer. Not every cartridge that fits the printer necessarily is the right type and using the wrong ink can cause unexpected results.
Nov 08, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon printing in streaks
first check the nozzle (bottom of cartridge). if u dont see black spots around the nozzle line (many nozzle that form straight line, black long straight line, color, 3 short line), or a view of burnt, u can continue below.
blow the air hole till it drop the ink. then clean it with water. but note, dont wipe the nozzle, let them wet. u must wipe the contact with dry tissue before inserting it back.
otherwise, u must replace ur cartridge :D
Apr 11, 2009 | Canon Office Equipment & Supplies
Canon Pixma IP3500 prints B&W with white streaks
as i can suggest you that it can be the problem of head clogged internally where you insert your black cartridge .and the other main cause is while you give a head cleaning command to get the cartridge cleaned it sucks or pulls  the ink from the cartridge in such a huge quantity that 3-4 cleanings make the cartridge totally empty .due to this the ink gets very low and the printouts come with streaks.many a times setting the print mode in best makes the copy perfect.but the printing gets too slow in that best mode.
Feb 26, 2009 | Canon PIXMA iP3500 Printer
Blank Ink not pumping to print head
Turn off the device after removing the printhead After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
Nov 22, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
Streaks / Bands of broken print area
First with a clean soft cloth and a very small amt of alcohol clean off the underside of the printer carridge (the holder for the print heads) also where the print heads cleaning station is clean out any large masses of congealed link. Then remove the ink cartridge in question and with a pencil eraser gently rub the contacts and both the cartridge and the carridge replace the cartridge. Using the software tools for the printer clean and align the printheads ( if there is an option to do so). If this dosn't fix the problem try a different ink cartridge.
Sep 04, 2007 | HP OfficeJet Pro k550 Printer
HP PSC 1350 All-In-One Thermal Printer Logo
173 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
