Where did you buy the bike? Any dealer who sells a bike is more than happy to instruct you on the use and maintenance of it. I will give you a brief, lesson-left hand controls the front brake and gears, right hand controls the rear (R=rear, easy way to remember). Front derailleur is the ranges 1 (closest to the bike are always easiest) and the farther away from the frame get harder but make the bike go faster. The rear derailleur has more than likely 7 cogs again same rule as above. So always pedal forward and do not go small gear in front to small gear in rear, & large gear in front to large gear in rear because your chain will stretch from too much stress and it doesn't do you any good.
Do not pedal backwards because unless your chain is directly on the correct gear you will chip teeth on your gears.
But, do go for lessons on your bike, to learn maintenance tips and how remove your wheels, etc.
Remember bikes are not toys, they are machines and need to maintained to get the full enjoyment out of them.
Testimonial: "Thanks ..dealer spoke with so much info ..missed some I'm afraid..willl go back now that I have special info needed..."
