Question about Maytag Heating & Cooling
We bought a 8000btu air cond and used it last summer. It is in a room 16X20. It has never seemed to blow cold enough air and will not keepthe room cool enough. I,m wondering if there is a service depot lose to us. We bought it at Home Depot, MEDICINE HAT, ALBERTA. It is a model # M6V08S2A-E Maytag.
  • 828 Answers
The A/C is small for the application. If there is any sun shining into the room it will add heat. If the room is open to other rooms the square footage it is cooling will multiply in proportion. Using a thermometer check the temperature of the air going into it and the temperature coming off of it out the grills. If the difference in temperature is 20°F or greater it is doing the job it was designed to do. If you shut it off when you leave and turn it on after the day heat has built up it will not seem to overcome it.
Posted on May 22, 2008
My Haier HPY08XCM 8,000 BTU Portable Air wont cool. How do I troubleshoot?
  1. HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015
    ? 1:59
    Apr 19, 2015 - Uploaded by Denada Pinoy
    In this video I review the HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015. ... No comments to display ... CommercialCool 12,000 BTU Portable Air Conditioner with Timer with Dan Hughes - Duration: 9:24. by QVC ...
Jul 21, 2015 | Haier HPY08XCM 8,000 BTU Portable Air...
Conia air conditioner reverse cycle - not blowing cold air; checked setting its correct.. it seems to blow cool air, but house is not cold. It was working fine last summer, not sure of problem.
If you feel cool air near blower, you have to service your unit completely. Because it's giving cool but not removing heat from room due to coil and air filter blocking. Helpful?
Dec 30, 2010 | Heating & Cooling
My Whirlpool window a/c is not cooling as well as it did last sum
I know it has been at least a year since your post. I am answering the post to terminate FixYa site activity on the post.
Remove the front cover. Check the routing of the temp sensor wire. It should go from the bottom of the control panel to the plastic clip in the evaporator coils. If it is touching the eavporator coils it will sense the refrigerant temp and cycle off early. If the unit is freezing up there is a restriction in the coolant lines and usually will require the coolant system be purged of foreign internal debris.
Thanks for choosing FixYa.
Jun 25, 2009 | Whirlpool ACC108PS Air Conditioner
Will not ignite properly
If you look at the wiring diagram in your furnace you will see that 4 blinks means there is either a blockage of air or your room air blower is not working. Check the air filter for any debris first. Then test the room air blower to see if it turns on and blows enough air prior to going out on code. Are all the dampers open both in the pipes as well as at the registers?
Oct 14, 2008 | Goodman GMS90703BXA Heater
2000 Bug
Is it not blowing enough air or is the air never getting cold the first may be a clogged cabin air filter a pain to get to need to remove the center and right side of the dash top plus anothe cover to get to it.
Jul 14, 2008 | 2000 Volkswagen Beetle
Seems fully operational but not blowing cold air
Sounds like you may have a small leak in the sealed system. If you don't have the receipt, contact the factory and provide them with your model and serial numbers, and if they fall within the warranty manufacture date, you should be able to get any Danby factory authorized service center to repair it for you, in accordance with the factory warranty policy.
Jun 02, 2008 | Danby DAC8003D Air Conditioner
Heating & Cooling Logo
93 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
