Question about Canon PIXMA MX310 All-In-One Printer
Jsut plugged in machine
And keep getting a message when I try to copy check thickness lever
  • 2,036 Answers
The Paper Thickness Lever should be set to the left for normal/plain paper. This switch can be seen inside the unit in the area of the paper output tray.
Posted on May 23, 2008
Error message
copy on my machine then i tray to copy
May 06, 2013 | Brother MFC-7340 All-In-One Laser Printer
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
make sure the thread has not come off the thread take up lever
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
Keep getting a "check original" message on screen - won't fax or copy
the check original relaates to the document you are trying to copy or fax check the guides for the document input and check you are putting teh doc in far enough yuoo can also lift the cover and check there isnt any obstruction .. basically the sensor that lets the machine know you have a doc on the go isnt getting actuated to start the process..try and put a thick piece of card in the doc feed part to see if it goes through it might push through the obstruction
Aug 05, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
I keep getting a sequence of orange and green light flashes. The paper won't feed and the message i get is " paper thickness lever problem" HELP!
in the side where you load the paper you can locate a lever that is lifted when you place the paper. just try to get hold of it. move it in either directions and then restart your printer without paper.
and once again with paper. everything will be fine
Jul 04, 2009 | Canon i850 InkJet Photo Printer
Will not print and keep getting paper thickness error
Did you try moving the paper thickness lever (blue lever on top of the print cartridge holder)? It should be all the way to the left when you start--if it needs to be adjusted the printer message will let you know.
Jun 27, 2009 | Canon i850 InkJet Photo Printer
Paper thickness error not clear
i have a brother DCR375CW and it will not print on card it keeps saying no paper feed , how do i set it for card thnaks
Sep 29, 2008 | Office Equipment & Supplies
Thickness lever
I just bought one of these printers and got the same message when trying to print from my digital camera... All you have to do is press the OK button on the printer!!! Don't feel too bad.. there is no documentation that explains this.. I only found this after I started frantically pressing all the buttons on the printer out of frustration.. Good one Canon.
Aug 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Failed to print
At the head you said 'paper thickness position'and then you seems to have ignored that and did all the other things. Is there an adjustment for paper thickness, a lever perhaps. It does seem to be with the paper feed or paper presence detection. Take a look around, is there something stuck in the paper feed track? Can you have pass a piece of paper through without it rucking up? Do these things see what happens Take a look also at www.fixyourownprinter.com
May 26, 2007 | Canon BubbleJet i550 InkJet Printer
Paper jam
OK, first try resetting th printer. This sometimes works the first time and corrects a lot of issues. Switch it off, take out all paper, check for jams with a torch right down back and open cover and check ther too. Once you are sure there are no paper jams (look really carefully they can be tiny!) unplug all cords and cables. Plug all back in turn it on, and try printing again. Post back if no luck and i will further assist.
Mar 16, 2007 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA MX310 All-In-One Printer Logo
291 people viewed this question
old marine
old marine
