TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
SOURCE: HELP!!
Well, in most calculators, the action of taking out the backup battery practically clears the whole thing. Memory, everything. I myself have a Ti-89 and have not yet experienced this problem, but I have on an older Ti-82 and removed the backup battery and the whole thing is dead now, or at least nothing happens when I turn it on, even after replacing the batteries again. If you still have the manual, I would check out the troubleshooting. If you don't have it, try to find it online. And if you have done both of these things, try getting hold of technical support through Texas Instruments.
SOURCE: will not turn on even
Having gone over two months without a response, I assume my suggestion to adjust the screen contrast solved the problem.
SOURCE: My ti-83 wont turn on. I changed all the batteries
I am sorry that I could not respond earlier. I am not sure of this but I think you can remove the back up battery and also the main battery, check the cells to see if there was a drain on the new cells , if so there is a short in the unit. If not keep aside for few hours and then replace the back up and then the main cells.
If there is no display there is some issue on the motherboard and might need a consensus.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1). Try a new set of AAA batteries. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system. Try a new set of AAA batteries. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
(Procedure 2).
~Connect the TI Connectivity cable between the PC and the calculator.
~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
