Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How to change defaults?
We have had this machine for some time and need to change the defaults. No one in our office seems to have an admin code. Is there a default admin code? I also can't seem to find a 1.800 customer service number for them. I find this customer user friendly machine very complex!! Thanks!
It is probably 12345687
Posted on May 27, 2008
Change c352 admin password
Mr. Gates, yes there is away to change the pw recommended you get a tech out to do it. Change admin pw not over the internet. Should have a paper work to back it up. Big time security thing Hard drive access and stuff
Feb 03, 2015 | Konica Minolta bizhub C351 All-In-One...
After trying to connect my mac laptop to ethernet suddenlink had a failure at the same time. NOWI CAN NOT OPEN THE ROUTER OOR ANYTHING. jim FOUTTY
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Linksys WRT160N Wireless Router
I forgot my nokia1208 security code IMEI:356071/03/722205/7 guys i need your help i want to use my phone.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Jul 25, 2011 | Nokia 1208 Cellular Phone
How can i get password to access router from my loptop via WIFI or how can i know the password that came from the factory
Most of the time the user manual provides the default user name and password for the router model. Most seem to come default with admin/admin. If this has been changed and forgotten press in the reset button for 10 - 20 seconds will reset the router to factory defaults. Usually
Oct 07, 2010 | EnGenius ESR9753 Wireless N Router Point ...
I need to put in some new account codes and delete the old ones
You need to be in the ADMIN. to change / enter codes. There is a separate code for the ADMIN. Input that code and you can change, edit, add new codes. If the ADMIN code was not ever changed then it will be the default code in the manual. Be ready because the code is not where you think in the manual. I believe it is is the setting section or check management settings. The default is usually 000000 or 111111.
Dec 18, 2008 | Sharp AR-M237 Copier
Toshiba Default code not working
Need to login to Admin mailbox 999 or 9999 (3 digit exts or 4 digit exts?) need to know admin password? once in follow prompts to edit maiboxes to reset password to default. Default is 997 and ext number,but the tech that setup your phone system could of change the default code(997).What Toshiba system do you have?
Nov 26, 2008 | Toshiba DKT 3010 Corded Phone
Possible to change default scan setting to PDF?
go into scan mode and select pdf, then go back to printer mode and select utility. user settings. store and current settings, then press store and it should use pdf as default
Jul 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
E-Machine-Microsoft office product code
Hi DeLaunay,
The product key that ships with E-Machines computers for Office is a trial key that is provided by Microsoft for a 60, 90, or 120 day trial. If that key was misplaced, a trial can be obtained directly from Microsoft at their Microsoft Office Trial website:
http://us20.trymicrosoftoffice.com/default.aspx
If a full version of Office was purchased along with the PC and they key was misplaced then you will have to contact Microsoft Support for a resolution. Their information can be found at the following link:
http://support.microsoft.com/oas/default.aspx?LN=en-us&x=10&y=10&gprid=2488
Geek Squad Agent Erik, Badge #2555
Geek Squad Secret Weapon
Go ahead, use us
Jun 03, 2008 | Microsoft Office 2003 Standard...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
147 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
