Question about Cameras
Have a problem with xd card
I tried uploading pictures from my xd card but was unable to since it did not read the memory card once i put it in.any of the card slots of the memory card reader of the cpu. when i put the card back into the card slot of the camera and turned it on it went into "CARD SETUP" giving me a choice of "CLEAN CARD" or "FORMAT" i chose the former  and followed the instructions "clean the contact area of the card with a dry cloth" so using the cleaner for my eye glasses, i did just that and repeated the process of putting it back in... but still i got the same page. will i lose all the pictures if i choose to format?
  • picadily Dec 26, 2008
    Champion:
  • 203 Answers
If it formats you will lose all data-sounds like a bad card-i don't know if i would take the chance and even use it if it does format
Posted on May 23, 2008
Memory Full or something esle?
Can you use any of the buttons on the back? A common problem for this model is keypad failure due to the connecting ribbon strip splitting, over time, where it is folded over.
All the buttons on the back of the camera run off the same ribbon. Only the on/off and shutter/zoom button run from a different ribbon.
For the memory problem, this camera has an internal memory but it is very limited and requires an xd card to increase memory capacity. If you cannot use the keypad to view or delete pictures then try either connecting a usb cable to the camera and computer or removing the xd card and use a card reader to view pictures.
If your pictures are stored on the internal memory then obviously you will be unable to view them if your keypad is not working and only by connecting to your pc via a usb lead will you be able to upload and view your pictures. You should also be able to delete them from the camera when plugged into your computer once you have uploaded.
Oct 16, 2009 | Fuji FinePix F470 Digital Camera
Format-less
put it back in the computer and try to format it there.
Jun 14, 2009 | Olympus Camedia C-350 Digital Camera
I have an hp officejet 7310 and use a 2gb sandisk memory card with my canon camera. what slot can i put the memory card in to upload my pictures onto my computer?
It depends if the 2 Gb card is a SD or a XD check the manual of your camera then once you know put it in the one that is labled the same
Jan 23, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Unable to upload pictures from memory card to computer
Most laptops that have a memory card reader will only read these types of cards, without needing an adaptor: -SD card -MMC card -Sony Memory Stick or Memory Stick Pro cards -XD cards
However, you have a MS Pro Duo card, although it fits into the card reader slot, the card is a lot thinner than what's expected, so the laptop won't be able to read it.
You need to put the Pro Duo card into the stanard size MS Pro caard adaptor. See attached image.
Hope this helps.
Jan 10, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
How do you put in a sd card in the hp mini to display my pictures
Kindly read through the following ,link, that gives you the correct procedure to put the memory card in your computer and the compatible card list aswell.
According to the product manual , the follwing types of memory cards are compatable with your system
The Digital Media Slot supports the following digital card formats:
● Secure Digital (SD) Memory Card
● MultiMediaCard (MMC)
● Secure Digital Input/Output (SD I/O)
● Memory Stick (MS)
● Memory Stick Pro (MSP)
● xD-Picture Card (XD)
● xD-Picture Card (XD) Type M
http://h10032.www1.hp.com/ctg/Manual/c00766888.pdf
Thanks
Proton
Nov 30, 2008 | HP Pavilion dv6000z Notebook
XD card picture error
Try to use a card reader instead. They are only a few dollars. I use one all the time, and hardly ever will use the camera on different models I have.
Never delete from the PC to the camera. It can cause corruption. Once corrupted, you may lose all pictures on the card.
Always delete from the camera, unless you will format the card anyway.
Use the camera and try to delete the bad picture from the camera. this may fix the problem, if not, try to read from another camera or a card reader...don't ever delete from another camera or the card reader.
The last is not good, and that means to format the card, and you will lose all which is on the card.
You may try to copy to internal memory.
One more thing... take out the card. reset all in the camera menu. Then reset all the things you like. Put the card in and try to read each picture in play mode only. If one picture is very slow, delete it. This may take some time as corrupted files may read slowly. then try again.
Sep 01, 2008 | AOpen Olympus 64Mb xD-Picture Card (AX4C...
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
XD CARD Terminal
hi i have the same problem at the moment
i was wondering if anyone has found a solution yet to fix it without losing the photos. your help would be greatly appreciated, thanks
Jul 11, 2008 | Olympus FE-290 Digital Camera
Internal memory fuji finepixa820
the only way to prevent it is buy a XD card
Fuji Finepix S7000 Zoom Memory Cards (xD-Picture Card - M Type) & Accessories The following memory cards are compatible with your Fuji Finepix S7000 Zoom. Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty. Your Fuji Finepix S7000 Zoom accepts xD-Picture Card - M Type cards. The largest xD-Picture Card - M Type card you can use in your Fuji Finepix S7000 Zoom is 2048MB
View all Fuji Digital Cameras
Feb 18, 2008 | Fuji FinePix S7000 Digital Camera
HP laser Jet 2840
Try using a different Memory card and see if it reads it, if not you might need to replace the memory card reader.
Oct 26, 2007 | HP LaserJet 2840 Printer
Cameras Logo
271 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
