Question about Panasonic DMR-ES46VS DVD Recorder/VCR
Panasonic DVD/VCR message U61
Message U61
  • wolfmanx4 Jan 04, 2009
    I was transferring movies to dvd when in the middle of the movie the dvd player just came up with the screen saying there may be a disc error and needs to do a self check to try to fix the disc. After the test it failed. Now the U61 message will NOT go away. The machine keeps saying the self check failed. I even unplugged over night and re-tried with no results.
  • calypso1225 Jan 04, 2009
    I just had the same problem while trying to record tv show. held stop and > like maual said too and it went away but now it says it has a disk when it does not and will not read the disk that it was playing 15 min before. Help
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~ glvw@nyc.rr.com
Thanks !
Posted on Oct 17, 2008
4 Suggested Answers
  • 11800 Answers
SOURCE: Panasonic DMR-EZ47V combined VCR/DVD has a U61
The service manual says that:
U61 = The unit is carrying its recovery process (with no disk in the tray) . If there is a disk remove it and restart the unit . This is the message that appears when the system's firmware crashed because of an incorrect command - normal operating procedure, just wait for it to finish. If the message doesn't goes away in 10 minutes after a power cycle you should force it: press the Ch UP and Ch DOWN buttons until the DVB Auto-Setup message appears on the screen.
If nothing you do has an effect and you haven't done anything to the unit when this message appeared then the fault is hardware - the processor of the unit has failed. The only way to fix that is to replace the mainboard. But that would cost about $175, more than a new unit, so it's time for a new one.
Posted on Aug 29, 2011
  • 11800 Answers
SOURCE: mt dvd/vcr combi displays a message U61 and the
Nothing is happening because the firmware can't recover/repair the error. Yes, you must take your unit to a dealer, this is a hardware fault and the faulty part must be replaced.
Posted on Jul 28, 2010
  • 25 Answers
SOURCE: Panasonic dmr-es35v dvd/vcr recorder reads hello, then u61, then
Plug AC power cord to wall electric socket if it is plugged into a surge protector or extension, if not try a different socket, if issue still exist have unit service.
Posted on Sep 25, 2009
Panasonic dmr ez48v
We recommend you unplug all AV cables connected to the system and test a different electrical outlet. If the problem persists, we recommend you use the below link to locate an authorized service center.
www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 21, 2014 | Panasonic DMR-ES40VS DVD Recorder/VCR
U61 fault on an EZ28
Review the reference U61 in the user manual or maintenance, its posible that its needs format special or type of dvd-ram,
This failure apparently is very common in this brand Panasonic.
you will think twice when You will go to buy Panasonic.
Jun 22, 2012 | Panasonic Televison & Video
Mt dvd/vcr combi displays a message U61 and the
Jul 28, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-es46v player recorder error code u61. what do i due
That error means: There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
I suggest you unplug all the cords o the unit and after 2hrs replug and see if the error is gone.
Let me know the result.
Thank you for using fixya.
Jan 03, 2010 | Panasonic DMR-ES46VS DVD Recorder/VCR
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Nov 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Sep 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
DMR-EZ25EB; Error code U61 cannot be recovered
take it to a tech to check about the system control chip... the contril chip would have gone bad... and they will replace u with a new chip..
thank u rate me!!
Feb 10, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
Panasonic DVD SC-RT70 whilst recording disc stopped and shows error code U61. Recovery process did not work message keeps repeating
I have a SC-RT70 model and there is U61 error code in my dvd player's display. what does this error means?
Jun 16, 2008 | Panasonic Televison & Video
Panasonic DMR-ES46VS DVD Recorder/VCR Logo
2,245 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
