Question about Black & Decker D2030 Iron
New iron, stopped heating and leaked water
I used this iron for the first time last night. Ironed a shirt, was working great, then when I was almost done, just the sleeves to go, it started leaking water from the steam vents near the bottom. Eventually, it appeared not to heat up again after I had unplugged and restarted it.
  • andrea05 Jun 10, 2008
    i have the same problem . i bought this iron new and started ironing when it began leaking as well. i thought it needed to be cleaned since this was my first time using it. so i tried to clean it according to the directions but i couldnt get all the water to work itself out of the iron. the next time i used it it was fine. however the third time i used it . it started ok but then started to blink and the resdy light didnt come back on and then i waited turned it off and tried again to turn it in but it didnt stay on and kept leaking water!
  • Black & Decker Master
  • 43,501 Answers
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 15, 2010
Iron is leakin onto clothing while ironing
Leaking irons happen more frequently when performing lower temperature ironing. Minimize the chances of this happening by doing the articles that require less heat with a dry iron. When you're ready to do the articles that require higher heat settings, add distilled water to the iron after allowing it to cool first (some folks suggest using rain water as it will lack the minerals contained in the soil - where water pumped from the ground picks them up).
Distilled water is recommended by manufacturers for irons. Use of regular tap water will cause mineral deposits to form inside the iron that can build up and even clog the openings on the bottom plate. These can contribute to stains on the material being ironed, too. If you are unable to obtain distilled water, you ought to descale the iron regularly to remove deposits that will form by heating water or allowing it to simply evaporate. Distilled water lacks the minerals to be deposited by either of these situations. If distilled water is used - there is no need to empty the iron before storing. Tap water - whether supplied by the locality or a well is loaded with minerals and may be treated with fluoride, chlorine, etc.
Descaling
an iron is pretty straight forward - no more difficult than descaling a coffee maker. Empty the iron of any water. Partially fill the iron with white vinegar and turn on to heat. Iron and old towel or rag to allow all the vinegar to pass through the steam openings.When empty, repeat once or twice - but with fresh distilled water to flush any remaining vinegar from the iron. When satisfied that the vinegar is out, store the iron. You can purchase products expressly made for descaling irons - just like you can for coffeemakers, but vinegar is a great low cost solution that works very well.
I hope this helps & good luck!
Oct 14, 2011 | Micro Pro 7599 Iron
Dirty iron
Goo Gone...
http://www.drugstore.com/products/prod.asp?pid=81908&aid=336064&aparam=goo%20gone&scinit1=goo%20gone
I have used this to clean sparay foam off of floors and many other things...you may have to soak a paper towel with it and then lay it on and let it soften the stuff up...but give it time an it will work on anything...
heatman101
May 06, 2010 | Rowenta DX6700 Iron
Fleece shirt melted on the bottom of non-stick iron
well try heating the iron and rub the wax on the heated iron and wipe it off using cotton cloth
Jan 04, 2010 | Sunbeam 4237 / 4238 Iron with Auto...
LEAKING IRON
This was happening with mine - leaving trails of water behind as well when I ironed. I took it all apart (figured it was already broken, what could I do worse?) I discovered that there is a rubber gasket around the hole that lets water move from the reservoir to the heating plate. The two surfaces (reservoir and plate) are held together by screws, which compresses and seals the gasket. The bottom surface of the reservoir section had been cracked (due to a drop on the cement floor, probably, and the two surfaces could no longer fit tightly together, the crack allowed it to flex, and water leak out. In other word, once it's leaking like that, it's time for a new iron. Sorry I can't offer a fix, but at least a explanation!
Jun 25, 2008 | Rival IR600 Iron
I have a Rowenta Professional iron that is spitting sometning onto dress shirts and leaving permanent marks. There does not seem to be anyone in Winnipeg, Manitoba Canada that can address this problem. ...
The iron probably needs to be cleaned. You can use half water and half white vinagar to clean. Hope this helps. Those white pieces are mineral deposit buildup.
Apr 01, 2008 | Rowenta Professional DE880 Iron
Water drips out of steam holes
I suspect that by placing it on its heel rest the water from the tank is not allowed to enter into the steam chamber and when you go into ironing mode there is a rush of water that is cooling down the sole plate to below steaming temperature. Try keeping it in the horizontal position on a heat proof pad and press the steam button just before going into ironing mode.
Sep 08, 2007 | Panasonic NI-H10NS Iron
Black & Decker D2030 Iron Logo
338 people viewed this question
Top Black & Decker Irons Experts
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
