screen size get enlarge itself i.e its like that pincushion setting get changed and again return to normal setting.this problem flickering all over the time.but i want to add one more thing that this problem isn't only in windows running, even in BIOS setup or startup screen.....so i am assured that this is not driver problem instead some monitor hardware probem.my monitor is just 2 yrs old.
Comments:
May 23, 2008
- hold the key[1] "main menu key" on monitor for 10 sec.
-   it still appears even its unlocked this dum **** of viewsonic SUCKs!
-   Guest
Mar 04, 2009
-   thanks it worked
-   Guest
Nov 04, 2008
-   My monitor -   Guest
Oct 03, 2008
-   viewsonic 17'' crt monitor shows osd lock repeatedly. i tried holding down all the keys on front panel of monitor for 10 secs & more than that as well but still no go. -   Guest
Press the [1] key & hold it for 10 seconds / till OSD Unlock appears on the screen. When OSD unlock appears on the screen , release [1 ] & press [1] or [2] key. This will unlock the OSD.
i cant install my monitor,its a view panel vg151, it only says ¨testing¨and doesnt...
(More)
i cant install my monitor,its a view panel vg151, it only says ¨testing¨and doesnt get any signal
I have a view sonic vp2130b a square about 3'4 of an inch has started in the center. It stays no...
(More)
I have a view sonic vp2130b a square about 3'4 of an inch has started in the center. It stays no matter where I go, or on line. It does change colors to what ever I was doing last. Do you have any idea how to git rid of this? Thanks
my problam with view sonic monitir 17"inches crt ...every time it shows memory recall ok? hw 2...
(More)
my problam with view sonic monitir 17"inches crt ...every time it shows memory recall ok? hw 2 solve this problem pls help me....thank you
the problem with my view sonic moniter is that a popup appears very frequently saying RECALL MEMORY...
(More)
the problem with my view sonic moniter is that a popup appears very frequently saying RECALL MEMORY OK??
