Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Bissell proHeat Pro-Tech 7920/7901 series or 8915/8910 series
How do I reattach the red float onto the top of the Tank-in-Tank. It fell off and I need a picture or description on how to reattach.
    President:
  • 1,673 Answers
Maybe this picture will help: (65 is the float)
bissell proHeat Pro-Tech 7920/7901 series or 8915/ - d5188ec.jpg
Posted on May 26, 2008
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
How do I use a brissell 7920 proheat carpet cleaner
PDF]ProHeat® Pro-Tech
banksvac.com/.../product_manuals/bissell/Bissell%20ProHeat%20Pro-Te...
USER'S GUIDE. 7920 / 7901 SERIES ... We're glad you purchased a BISSELL ProHeat Pro-Tech heated formula deep .... assembly and operating instructions, safety precautions, as well as ... *SmartTemp heats the cleaning solution for carpet.
Sep 29, 2015 | Vacuums
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My bissell proheat pro-tech isn't sucking up the solution
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Mar 19, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell proheat used does not put out water
The spring your talking about goes where the trigger switch is. You need to dismantle the entire unit to access this, remove 6 screws on hood, two main handle screws, two tool caddy screws and finally two lower back housing screws. Removed top handle and gently open unit up
Aug 29, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell proheat 2x wont vacuum up water
There is a float (usually looks like a red ball) that rises up if water is in danger of getting to the motor. Sometimes they stick.. Give it a poke to free it up.
All the best,
WD
Aug 18, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do I take apart my Bissell 7920 ProHeat Pro-Tech
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Jul 16, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Need new tank, poured boiling water into and melted bag
go on the internet and go to bissell.com.you can order one from them or go to the nearest vacuum cleaner repair shop and you should be able to get from them
Apr 27, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
I have a bissell proheat 8910 steamer and my red float fell out of the tank-in-tank. i need to know where it goes please. thanks!
the rounded part of the red float goes inside the bottom part of the tank in tank. If you push the bladder down with your hand you can see grooves on the inside of the bottom tank intnak. This is where the rounded part goes. the longer more straight part of the red thing sits straight across on top of the bottom unit on the straight edge. I honestly cannot remember how exactly I got into place but I finagled it in I am sure...
Mar 12, 2009 | Bissell 8910 ProHeat Clear View Upright...
Fit a pump to Bissell proheat 7920e
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
wtqy
Jan 09, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
312 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
