Question about Averatec 6200 Notebook
No Power My Averatec 6200 laptop fell off a stool I was working at and suffered a slight bump on its right side next to the monitor port. Now it will not power up.
    Champion:
  • 207 Answers
I belive battery is displaced reset the battery and then see
if not then the power cord inside teh machine is unpl;ugged
then u nneed to chk wd the tech
Posted on May 22, 2008
My averatec laptop will only power on to a black screen but it still sounds like its booting
1) Laptop on use a flashlight, and shine it at the LCD screen. Shine at various angles.
Do you see faint images?
2) You can also plug in a VGA monitor to the back of the laptop, (Laptop OFF, monitor off), and toggle over.
(It can be a VGA monitor that looks like a small TV {CRT}, or an LCD flat screen that has a VGA cable attached)
Plug the VGA monitor's cable into the blue VGA port on the left side, of the Avertec 3200 Notebook PC.
(Example of VGA connectors,
http://en.wikipedia.org/wiki/VGA_connector
Turn the VGA monitor on. Give it time to 'come to life'.
Turn the laptop on.
Are there graphics on the external monitor? If not press, and hold down on the Fn key, (Blue Fn next to the CTRL key), then tap the F2 key.
(The F2 key is the toggle over key for an external monitor. You can use the laptops LCD screen, or it's screen, and an external monitor)
Graphics show on the external monitor? Your graphics chip is good.
Problem is with the screen Inverter, or the Backlight.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is used to convert the electricity from the laptop, for the LCD screen, and the Backlight.
90 percent of the time the fault is the screen Inverter.
The Display Assembly essentially is;
1) Top cover of the laptop. (Display Cover)
2) LCD screen
3) Display Bezel. (Thin plastic frame in front of the LCD screen, and surrounds the LCD screen)
4) Inverter
5) Backlight
6) LCD screen frame
With the Display Bezel removed, the screen Inverter should be at the bottom/front.
This is an example of a screen Inverter for an Averatec 3200 from a quick search,
http://www.laptopaid.com/averatec-3200-lcd-inverter-board-76-030105-02-tested-1629.html
I haven't worked on an Averatec 3200 Notebook PC before. I have worked on 100's of other laptops.
The sequence for removing the Display Bezel follows a pretty standard approach.
Looking at the Display Bezel I see four screw covers. (I'm looking at a PDF Users Guide)
One at the top Right corner, one at the top Left corner, one at the bottom Left corner, and one at the bottom Right corner.
These screw covers made of a rubber-like material. (Synthetic rubber) They are slightly rounded on the top. They have a type of rubber cement that holds them in place.
I use a computer pick to gently pry them off. If you carefully pry each screw cover off, and set them down sticky side up, (Screw side), you can usually reuse them again.
Screw covers (4) removed, use a Philips head screwdriver, and remove all 4 screws.
The Display Bezel will still be held in place. It has plastic tabs on the outside edges that snap into the Display Cover. (Top cover of laptop)
A fingertip is used on the INSIDE edge of the Display Bezel, next to the LCD screen.
(WATCH your fingernails against the LCD screen)
The fingertip raises the Middle/Inside edge of the Display Bezel, just slightly.
Now use another fingertip on the opposite side. Raise the Middle/Inside edge.
The Display bezel should start 'popping' out. (As the plastic tabs release they make a popping, or snapping sound)
To illustrate this technique further,
http://www.insidemylaptop.com/replace-damaged-lcd-screen-dell-latitude-e5400-e5500-laptop/
http://www.insidemylaptop.com/replace-lcd-screen-inverter-dell-inspiron-1525-laptop/
(One more, to show you where I believe the screen Inverter is for the Averatec 3200 Notebook PC, and what an average screen Inverter circuit board looks like,
http://www.insidemylaptop.com/remove-screen-inverter-dell-studio-1737-1735-laptops/
When the Display Bezel is loose, you slide it to one side a little to ease it around, and off, of the cover latch.
The cable connectors going to the screen Inverter are shaped differently from each other, so that when you go to reinstall them, there is no chance of mixing them up.
With the tools you have available, I would replace the screen Inverter ($7 plus shipping), and see if this repairs the problem.
If not the problem is the Backlight. Most of the time you have to buy the LCD screen, as the Backlight is an integral part of it, and should be replaced by a professional.
[ An LCD screen is composed of layers. The layers are held together in the correct alignment by the LCD screen frame.
This alignment MUST be aligned as it was from the factory.
This gives you an example of replacing a Backlight,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Make a mistake here, and you can throw your LCD screen in the trash ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 21, 2011 | Averatec 3200 Notebook
Dropped Averatec 3200 laptop and it fell on the cord and bent the power source connection. Can I fix this or do I need to send for repair?
I've had this happen to me a few times. If the pin inside the laptop is bent, then there is no question that you'll need a warranty or shop repair on the laptop to fix or replace the power port.
If the power input coming from the power supply is bent, then you can try fixing it by pushing the plug back into place with a pair of pliers. If this doesn't work, then you'll need a replacement power supply or repair.
Apr 03, 2010 | Averatec 3200 Notebook
I need to hold manipulate power cord just right in
You can buy a replacement motherboard on ebay for $150, but then you will have to pay someone to replace it. That could cost as much as the motherboard itself, so it is up to you how much you are looking to spend on this system.
Good Luck
JL
Dec 30, 2009 | Averatec 6200H Notebook
7100 cmos battery location
Hi!
Ok, what you really want here is a service manual for the 7100. That would show you how to pull apart the case in order to get to the mother board (which is where the cmos battery is located).
After a bit of searching, it's proving hard to find. This link might be the next best thing though:
http://fatpenguinblog.com/scott-rippee/averatec-6200-laptop-deconstruction/
It's a deconstruction guide for a 6200. It will be very similar to your 7100. A word of warning to be careful of course - laptops are assembled with a lot of small parts & many small screws..so take your time & make a note of any variations to the 6200 guide so you can reverse the steps when you're done with the battery.
Hope this helps!
Dec 04, 2009 | Averatec Computers & Internet
MY AVERATEC 6200 WON'T POWER UP, NO LIGHTS
I recommend you to try the steps in the below weblink
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Follow the steps from No power or no boot
Jul 07, 2009 | Averatec 6200 Notebook
Can not take a part my averatec 6200
There is no such manual as this is a dangerous self fix. Look for a generic OEM replacement on Ebay.
Apr 10, 2009 | Averatec 6200 Notebook
Averatec 6200 laptop drivers
Here You can get all drivers for Averatec 6200 series http://www.trigem.com/us/support/drivers.asp
Aug 21, 2008 | Averatec 6200 Notebook
Averatech
Could you suggest me to down load a sound card for Averatec - 6200
Mar 16, 2008 | Averatec 6200 Notebook
Repair issues...
Please visit http://www.averatec.com/docs/5100-doc.pdf and look for your solution.
Mar 23, 2007 | Averatec 5110HX Notebook
Averatec 6200 Notebook Logo
52 people viewed this question
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
