Question about Logitech MX518 931352-0403 Mouse
Logitech mx518 hi my mouse [logitech mx518] sometimes freezes randomly for no reasons. i have vista and i have installed the latest drivers for my mouse but still no joy. help please?
  • 6 more comments
  • joseffamador Oct 11, 2008
    i have the same problem, mouse will be working fine, then momentarilly "shut off" (que USB device removed sound), then work again for no reason (que USB device plugged in sound)
    It will do this about 5 times then turn off for good util I unplug it and plug it back in.
    rinse repeat.
  • ursohaha Jan 05, 2009
    I have the same problem as above. Mouse momentarily shuts off with USB removed sound, after 1 second USB plugged in sound and mouse works again. This seems to be happening when I'm playing a game but not in normal desktop use.
    I dont have enhanced precision checkbox set, so the solution below didn't help me.
  • Anonymous Jan 07, 2009
    I get the same thing. It worked fine at first, but it's gotten worse lately. Sometimes the mouse just stops registering for a second or two. Sometimes it spontaneously lowers the sensitivity, but that's easily fixed by nudging the + button on the mouse. But then it'll turn off completely, the light underneath will turn off and the only way to fix it is to unplug and replug the USB cable. I'm on Windows XP, by the way. Turning off enchanced cursor precision is not an option for me. If I do and still want to keep the same sensitivity, the cursor movement becomes too jaggy. It skips pixels, and being a 2D and 3D artist, it disturbs my workflow far too much.
    But annoyingly, it seems to happen more often the busier the computer is. Particularly when playing games. Very rarely when browsing. But sometimes when opening a new window or attempting to start up a program.
  • Anonymous Jan 09, 2009
    Mine doesnt have as much of the sensitivity switching, but it does cut out, usually from moving the mouse upwards and downwards quickly.
  • Venari Jan 20, 2009
    My MX518 mouse often turns itself off for no apparent reason. Most recently was a few minutes ago; all I was doing was idling on the desktop with Notepad open. It was working one minute, and when I went to check my MSN contacts, I noticed it wasn't. Replugging the USB cable doesn't work for me. Had to reboot the whole computer.
    Windows XP.
  • pvsmith161 Jan 23, 2009
    I have had this mouse for the last year or two, and only within the last month it has started randomly freezing on the screen. A reboot is the only way I can bring it back to life.
  • Anonymous Feb 03, 2009
    I have the same stalling problem, appeared lately. I'm not using the enchance precision feature, but it still bugs. :(
  • Anonymous Apr 28, 2009
    I have the same problem, my mice just suddenly started to turn off time by time. Usually happend with a margin from 10-20 sec to maybe 2-5 minutes if I'm lucky.
    I've never before been in need of the drivers to any device for this computer, but even when I installed it there wasn't any change.
    Someone with a Solution, help us! Before it's too late... (Or I'll buy a new one.)
    President:
  • 2,712 Answers
To work around this problem, turn off the Enhance pointer precision feature: 1. Click Start, click Run, type control mouse, and then click OK. 2. Click the Pointer Options tab, click to clear the Enhance pointer precision check box, and then click OK.
Also see this article from Logitech.
The surface on which you use the mouse plays an important role in its tracking. The optical sensor must use the pattern on the surface to track the position of the cursor. Therefore, using the mouse on a glass or otherwise see-through surface will inhibit the ability of the sensor to track the cursor. Also, if you are using the mouse on a reflective surface, such as a mirror or shiny metal desk, you may experience tracking problems. In both these situations, try using the mouse on a mouse pad or piece of paper. By using the mouse on a white sheet of paper, you can also conserve battery life. Other surfaces that have been known to cause tracking problems are:
  • Some wood grains
  • Grooved surfaces
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 22, 2008
I Removed the USB Cord and put one from an older MX mouse. Worked perfectly
Posted on Aug 13, 2009
    Problem Solver:
  • 7 Answers
I could never get my MX518 to work properly. Without the SetPoint drivers, the mouse wheel did not work. With the drivers, although the mouse wheel worked, my computer stalled on bootup and typcially after a couple of minutes would work without error, though sometimes apps would respond only after several clicks. I have a PS2 KVM and could never get the mouse wheel to work with it (with or without the SetPoint drivers). I wandered over to the Logitech boards, interested in using my KVM again, and found this tip, Clean Boot to try and track down the issue. It turns out, the default system.ini file (which has compatibility settings for 16 bit applications) was the culprit. Of course, since this is installed by default with Windows XP, Logitech's the real culprit for not detecting this and fixing it on their product... but when I got rid of the contents of my system.ini (do at your own risk...) not only did the mouse work with PS2 (with or without SetPoint), but so did the weird stalls/freezes at bootup and everything seems to work as it should now. I had no idea my stupid mouse was causing so many issues... but all is well now:)
Posted on Jun 24, 2008
I was able to solve the problem by uninstalling Logitech setpoint driver and letting Windows use the default mouse driver. Here's what I did (I'm unsure which steps are unecessary, but this is what I did and it worked):
disconnect MX518
plug-in another USB mouse
uninstall Logitech drivers
restart computer
disconnect mouse
plug-in MX518 again
This removed the problem for good. I'm using Windows XP home edition. Good luck!
Posted on Jan 17, 2009
Problems whit logitech mx518 mouse left click sometimes work and sometime no, how do i fix the left click
It sounds like the micro switch needs replacing inside the mouse. At the end of the day it is probably cheaper and less hassel to go out and buy a new mouse.
Aug 01, 2010 | Logitech MX518 931352-0403 Mouse
The scroll button of my mouse logitech mx815 is not working, what should i do??
Try reinstalling the driver software for your mouse. Best to uninstall the old one first. You could also download the latest version from logitech website.
Mar 14, 2010 | Logitech MX518 931352-0403 Mouse
My mx518 is freezing it disconnects from my computer it makes the disconnect sound and than takes a little while for it to reconnect it only started happening today. And it changes my sensitivity in...
if its battery powered thats the issue. 2 other possibillities there is a faulty connection or the mouse is bad. Replace it, return it or exchange it. Also u should take the time to clean it every 2 weeks or month
Dec 13, 2009 | Logitech MX518 931352-0403 Mouse
Red light stop for MX518 (logitech)
hi,
either try connecting the mouse to another USB-port or another computer to see whether it works with another machine. IF it does not the mouse is broken and you will have to get a new one.
Good luck
Sep 29, 2009 | Logitech MX518 931352-0403 Mouse
Logitech mouse M-SBF96 Not Working Properly... I had LogiTech MX518 and when I pluged out usb of MX518 and pluged in M-SBF96, M-SBF96 didnt Work... I was thinking that driver didnt recognised it and i...
Hi, Please uninstall any logitech software version present on your OS (if available) - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if
possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for
new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect
the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware
failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Jul 14, 2009 | Logitech M-SBF96 Mouse
Pointer moves when clicking even is mouse is not moving
just open ur mouse
and clean it with cotten
and u will never got thsame problem.....
Jun 26, 2009 | Logitech Gaming-Grade MX518 (9313520914)...
Mx518 cable problem
Most PC repair shops can make you a new one.
The mouse itself is only around £20.00 / $40.00
Jan 13, 2008 | Logitech MX518 931352-0403 Mouse
MX 510 freezing
Same problem been getting worse. Figured out that the mouseware driver is outdated and not compatible with win xp. Use logitech's setpoint for mx518 or uninstall mouseware. Now no more freezes
Oct 11, 2007 | Logitech MX510 Performance Optical Mouse...
Logitech MX518 931352-0403 Mouse Logo
5,305 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
