Question about HP Pavilion dv9000z Notebook
Vhs to dvd
Can't afford a tv card to be put in my new laptop
  • 1,031 Answers
If you cant afford a TV card on your laptop and you have a digital camcorder that supports AV-IN. When you do this Igo from my VCR to the camera then to a firewire port on the PC. The camera will acts as a bridge. then burn the cd with the software Nero 5.5xx .
Posted on May 22, 2008
Trying to set up a dual monitor with onboard VGA and with Sapphire radeon x300 video card. The Radeon is taking over and not letting the motherboard vga work.
sir the mother board accept only one VGA card if you installed a new one the the other on will disabled if f you wanna run multi screen at the time just but the multi VGA dongle hub it is affordable and works fine dont need any driver buy it it`s useful affordable and have fun
May 23, 2011 | ATI Sapphire RADEON X300 SE 128MB DDR...
The problem started when I was watching a tv show and my laptop shuts down, then I tried to turn on again, and I couldn't. When I press the power button to turn on the laptop, the keyboard lights come on...
Dear Friend,
HP Pavillions are not good... Buy a new Laptop that dosnt use Nvidia graphics card.
The problem resides in the graphics card Heating up to madness.
If you know how to open your Laptop, Dissassemble it and remove the processor. Heat up the Graphics card with a hair blower for 5 to 10 minutes. put the hair dryer about 1 cm distant to the graphics card.
After that - let it cool and make sure you put back everything correctly, screw it up and Voila...
Your laptop is new again..
Nov 25, 2010 | HP Pavilion Dv6910us Notebook
Where and how do you put the memory stick pro duo memory card in your computer/laptop?
First check whether your computer have aport for that. Foe ensuring it call the customer care of sony which iwill be a toll free number ask them with mentioning your specific model number.
Or you can just buy one cheap memory card reader which supports sony Memory Stick PRO Duo Memory Card. Its very cheap, i am sure you can afford it. Its good for you as one single card reader will support lots of types of memory cards and sticks.
Oct 06, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Replacement video card gateway mx 3210 notebook
Unfortunately you have a lap top and the Video card is built into the motherboard. You have two choices. 1. Send the unit to Gateway and have the motherboard replaced, expensive and time consuming. 2, Replace the laptop with a new one, expensive but most likely a better solution.
Oct 15, 2009 | Gateway MX3210 Notebook
Express card and TV tuner not working
Reinstall the drivers, just put the driver CD given along with the card, and autorun. OS will automatically list the available drivers and select driver for windows xp or vista and give OK. That's all.and make sure that your vista or 7 rc is set to signal area .like australia india
Jun 24, 2009 | Acer Aspire 8920-6671 Notebook
Renault scenic key card will lock and unlock doors but in ignition says card not detected
possible card fault!,ive had same problem with mine .after getting help from rac ,found reader faulty[worn], so if card reader hanging down[out of console]put card in at slight30 degree downward angle would work ,although had to tie strap it so would keep in position but works safely. on getting new card reader £67.17 from renault and fitting it, found that card is fault so just swapped back to old reader untill can afford new card and programming£150. from renault hope this helps rich i...
Jun 17, 2009 | 2003 Renault 181
Graphics Card buying help
First of all you cannot change the graphics card in a laptop computer, they are integrated.
There aren't any external video cards for laptop gaming yet. There is a standard for removable laptop video cards called MXM, but few laptops actually use it.
This is the concept for an external video card >>>>
http://arstechnica.com/news.ars/post/20060802-7409.html
Unfortunately these devices cost a fortune (well over $100)
In conclusion if you wanted to up grade your graphics card you would need to purchase a new laptop with the graphics card you want.
Alien ware laptops come highly recommended.
Regards
Jun 12, 2009 | HP Compaq nc6320 Notebook
Copy video to laptop
you need a capture device, like a capture card or, if you cannot afford one, at least a tv tuner (on usb) be careful though, if you buy one, to be both digital T and digital C, otherwise you will experience unpleasant surprises. (as myself, when I bought a cheap one, it was just digital T, so I couldn´t use cable tv or the likes of it because it needed digital C for the job...)
May 26, 2009 | Sony CCD-TRV238E Camcorder
Help me to find Laptop Analyzer Diagnostic Card
Most of the time you don't need a Diagnostic card because you can swap components and if you get POST error codes they detail the faulty component.
The Diagnostic card can point to motherboard problems but 90% of the time motherboard faults with surface mounted chips cannot be fixed easily.
May 23, 2009 | Computers & Internet
Uploading pictures from camera onto computer
Go to a computer store there they should have a cheap/affordable usb cable or better a memory card reader where you can put your memory card into, it will connect to your computer/laptop and from there you should be able to upload pictures. and no you do not need to install anything at all. =) icyfyeress@hotmail.com
Apr 10, 2008 | Optimus DS-5080 Digital Camera
HP Pavilion dv9000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
