Question about Toshiba Satellite Pro 6000 and 6100 14.1 LCD Display LQ141X1LH53 (P000316660) CD-ROM Drive
Blue Vertical Line on my laptop screen
Since downloading pictures from my camera onto my hard drive, I now have a vertical blue line on my screen. How do I get rid of it????
  • Anonymous Oct 23, 2008
    blue vertical line on screen
  • 4 Answers
Does the line still appear if you plug it into an external monitor? If not sounds like your laptop screen has developed a fault, unlikely to be related to what you did with your camera just coincidence. The only way around this would be to replace the laptop screen. Not an easy job but not too difficult if you can find the same screen for sale on Ebay for example. Either that or replace the laptop and sell the old one on ebay for someone else to fix. Hope that helps Chris
Posted on Jul 26, 2009
Have line on the top black vertical line not so clear but its not normal
Please check if the problem can be seen in the BIOS screen. - you can go to the BIOS screen by tapping F2 repeatedly as soon as you turn on the computer.
If the vertical line can be seen in the BIOS screen, it is already a problem with the LCD screen and you need to contact the computer manufacturer for possible LCD replacement if your computer is still in warranty.
Hope it helps you.
Apr 17, 2011 | Toshiba NB305-N410BL 10.1 inch Mini...
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Aug 02, 2010 | Electrograph Systems DTS4230 42 in. Plasma...
Blue vertical line on LCD screen
Thus meaning what display on the LCD is exactly what "enters" through the lens. Is this a hairline or thick line appearing on the LCD and does the same happen on the photos/pictures when they are downloaded on a PC? If so "something" could have infiltrated into/onto the camera lens....
Jul 16, 2009 | Canon PowerShot SD890 IS Digital Camera
Red vertical lines and horizontal flashing lines on viewing screen plus fuzzy picture.
Its bad ccd imager problem in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 02, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
LIGHT BLUE VERTICAL LINE ON MONITOR
The vertical line is a bad pixel sensor at the edge of the screen, your screen has hundreds of vertical and horizonal pixel sensors. This is an indicator that the screen is going out and need replacing.
Jul 03, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
White screen on LCD and two vertical lines-1 red & 1 blue
Hi, check the lense. It might be dirty or you may have left the lense cover down.
hope this helps,
Eric
Dec 31, 2007 | JVC Everio GZ-MG130 Camcorder
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
Computers & Internet Logo
475 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
