Question about Galaxy Radios DX- 88HL Base CB Radio
No receive no output
Makes clicking sound trys to but wont ..
fm seams louder than am
big prob's i dont know
  • Galaxy 88 May 22, 2008
    makes clicking sound when trying to transmit (meter moves funny not right and low volume on am no receive
  • 92 Answers
The final transmitter is out, this is normally caused by a bad antenna, you will have to take it to a shop unless you know how to fix it yourself. Before you hook it back to the antenna you have, check the wire with an ohm meter to make sure there is not a short. If you can also try and hook the antenna to a meter that checks reflective power, this is power that is reflected back towards the antenna because of metal, like the hood up. Too much of this and it will also burn out the transister in the CB. This and the mic are the #1 repair issue at shops.
Posted on Sep 10, 2009
  • 64 Answers
It does sound like a power supply problem with low voltage because there is not enough current (Amperage) getting to the circuits in the radio to allow it to function properly. Try a different power supply or power cord or move it to another vehicle if mobile and see if the problem follows the radio if it does it could be a bad or cold solder joint in the radio or a bad power switch I have seen both often after these radios got some age on them. Hope this helps, if you have the expertise perhaps you can fix it if not take it to a reputable CB Shop and tell them the symptoms if they have not seen this problem offer the suggestions here.
Posted on Sep 12, 2010
  • 67 Answers
Sounds rather like a power supply problem.
Posted on May 25, 2008
  • Ray Murphy May 25, 2008
    Sounds like power supply problem.
I want to connect a ps3 to my new pioneer receiver
if your tv has audio output, connect from there then into your pioneer
Nov 22, 2017 | Pioneer Audio Players & Recorders
Technics SA-AX530 all modes not working - no sound
Not a good sign. There should be a click a few seconds after you turn on the unit. That says the output section is OK. If there is no click, you need repair. Perhaps only some fuses inside, but it could be worse.
Also make sure that the speaker switch is in the right position, like A, not A+B. Also the headphone jack can silence the speaker.
Make sure that ALL switches are in the right position.
Dec 17, 2013 | Technics SA-AX530 Receiver
I just picked up a used Onkyo TX-SR502 receiver that has no audio output on any of the channels. I obtained a service manual for it and have tried a few things, but dont know the source of the problem...
I have the same problem, how did you initiate debug mode ?
The receiver worked perfectly until a few days ago, then one day it didn't work when I turned it on but started working after a few minutes. The next day it did the same thing and the folowing day it didn't work at all. Have tried the power reset and also had the top off to see if there's anything really visibly burnt - nothing.
This receiver never got bad treatment, left on overnight a few times but not with sound running out, just powered up. It's a bit enclosed I guess so maybe overheated but I find it hard to believe.
Anyway, can someone advise how to initiate debug mode and also what to do with it.
Oct 04, 2010 | Onkyo TX-SR502 Receiver
How do you get audio output from gpsmap 640?
Better if u connect it through FM tuner on your car radio
Jun 25, 2010 | Garmin GPSMAP-640 GPS Receiver
Receiving AM & FM stations but NO AUDIO OUTPUT
Please post the make and model number of your radio to help us help you.
The more information you provide, the more specific and accurate our solutions can be.
Apr 15, 2010 | Audio Players & Recorders
I have a 1992 toyota pickup 4x4 2.4 manual trans that trys to engage into 4 wheel drive on its one and whene i want it to it wont go in 4 wheel drive. I ALSO NOTICED that the 4x4 indercator light will...
G'day mate yes you have a prob and i think it is empty 'transfer' case Toyota had a big prob with transfer case pushing oil into gearbox , result transfer case empty gearbox full. fix is when you get the transfer case off (maybe have stripped and checked ) then drill a small hole in the front of the transfercase at gearbox filler bung height and run the same oil in both if its a manual that is. hope this helps
Apr 04, 2010 | 1992 Toyota Pickup
Does it matter which wire of the pairs for speakers gets attached to either of the two speaker connections...
yes it does matter you get get static feedback,,make sure you attach the right colors to the right side,,,plus rear speakers are louder so you dont want your sound to sound weird
I just bought a pioneer pl-200 turntable at a flea market. I plugged it into an old am/fm/8-track amp's phono input and I know the amp cranks on fm but on phono, it's very low sound. It does get louder...
Turntable signal outputs are very, very low amplitude and either have to pass through a pre-amp before being connected to an amplifiers "ordinary" inputs (e.g. aux), or connect to an amplifier's specific turntable input in order to give the "normal" levels of volume.
This is because the cartridge (the bit that has the stylus or needle on it) can only generate very small amplitude signals.
As turntables are now outdated, a lot of amps no longer have a turntable input any more.
Unless you can also find a cheap pre-amp or an old amp with a turntable input, you may have wasted your money.
Sep 21, 2009 | Audio Players & Recorders
Sound problems on my turntables
yes ground the turn tables usally have ground wire u tie on to bolt on back
Oct 07, 2008 | Yamaha RX-V995 Receiver
Center Channel problem!!!
fm is sterio thats why dont use it in that mode use sterio mode only for movies with voise ok
Jan 26, 2008 | Denon AVR-485 Receiver
Galaxy Radios DX- 88HL Base CB Radio Logo
138 people viewed this question
Top Galaxy Radios Radio Communications Experts
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
