Question about Philips 55PP9352 55" Projection Television
Philips 55" hdtv rear projection internal parts
I need a ballast power supply and cable for philips 55pp935217
  • Philips Master
  • 8,617 Answers
If your model number is 55PP935217 you dont have a ballast. You have a rear projection with 3 CRts . Please let me know if thats the correct model number and what your symptons are. I will be able to help you get what ever part youre needing.
Posted on May 22, 2008
55" Philips rear projection HDTV..
that input is called DVI digital video interface it is only for video. there should be some red and white composite input jacks for the audio near the DVI connector. you will need to hookup the red and white cables from the tv to the cable box or dvd player or whatver you are using. good luck
Jan 06, 2011 | Philips 55PW9363 55" Rear Projection...
Picture looks like its red and green 3-d,Phillips 55pp935217
Ur convergence it dead,Need a convergence kit,use what in that kit,Know how to solder righht?Tries Tv Repair World.com,Ebay.com.
Oct 06, 2009 | Philips 55PP9363 55" Rear Projection...
55pp935217 black screen with sound
Common problem with this model. Goto www.TvRepairKits.com and get their instructions on how to fix it.
Jun 16, 2009 | Philips 55PP9363 55" Rear Projection...
Philips Projection HDTV 51pp9303h/17
Number is on your STKs in TV Two big black ICs STK392-110s 150s, use 180s For Parts Electronix 1-800-223-3205 As for sound replace microboard has #P on it.
Jan 01, 2009 | Philips 55PW9363 55" Rear Projection...
Have phillips 55 hdtv that needs convergence badly
OK, friends.. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms.SOme time SSB is defective ( small signal board, replaced it ) If you have questions? noetvs@embarqmail.com . Good Luck !!
Jul 12, 2008 | Philips 60PP9202 60" Rear Projection...
55pp935217
OK, where to purchase the is focus box? Part number 54945198.
It is not at the philips store. Help!
May 30, 2008 | Philips 55PP9352 55" Projection Television
Philips 55 inch rear projection tv
When it is on, do you see any distortion in color?  If not probably bad power supply board. Call 1-800-543-4330 and have model and chassis number and ask for Power supply/deflection board. Only about 200.00
May 29, 2008 | Philips 55PW9363 55" Rear Projection...
55 hdtv philips having issues with blue and red lines around everything ......
change the convergence ICs also check the resistors right next to the ICs as 1 or 2 of them may be open as well.
Mar 28, 2008 | Philips 55PP9352 55" Projection Television
Philips 55PP9352 55" Projection Television Logo
301 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
