My Canon ir c2100 has a paper jam issue.
I replaced the fuser but the print passes half way through and then jam every time. The print is good and fused but won't continue to output due to the jam. HELP
CHECK THE VERTICAL ROLLERS , MAY DIRTY
Posted on Aug 12, 2008
  • 1,326 Answers
Have you tried to run copies from both paper trays? Will it jam in the same spot with both trays? If one works, but the other jams, it may be as simple as making sure the paper tray is set to the correct paper size? Is it set up in the paper tray as LTR, but the tray is saying LTR-R on the display. If so just change the paper size knob to the correct size. Also, if it stops in the same spot with all of the trays, look for something blocking it. Also, try to cheat the side door and make sure everthing is turning correctly.. Good Luck...
Posted on May 23, 2008
Canon ir 3300 have a problem for paper jam in fixing film so how to solve the problem
there is an error in the rotation of the fixing film.
check the fixing film sensor and make sure that all the wiring and the connectors are connected securely.
if it persists, consider replacing the fuser fixing film
thanks
Aug 17, 2014 | Canon IR 3300 Digital Copier
Canon ir2016 jams papers under registration clutch. the clutch runs on power up but does not run when copig or printing help
This seems to be a common problem for the Canon ir 20 xx series machines. The problem is having machine indicating paper jams on the left hand side of the machine. When you open the left cover you do sometimes find paper stuck on entering the fuser unit. The main problem, and loads of these machines with these problems have been fixed, are the half moon pickup rollers! Clean the pickup rollers or even better, replace them and you will get the machine working 100%!! To confirm this try copying from the machine using the manual feed tray. You will never get a paper jam. This fault is due to incorrect pickup resulting in timing problem and thus getting paper jams! Good luck!
Mar 10, 2014 | Office Equipment & Supplies
Hello , i have cannon IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
There might be an issue with the feed clutch or fuser. It depends on where it jams in the machine.
Sep 27, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Paper jam problem
Replace the paper pick up & paper feed & paper sep. rollers in the paper tray... Good Luck
Sep 01, 2012 | Canon iR 2016i Black and White Copier
I have canon 2900 and it having every time paper jam problem please help me
Analyse where paper jamming is happening? remove right left back & top covers..press door switch, shoot print command. Remove cartridge after paper jam, check upto where paper travel?
1. If paper jams with curl foldings in cartridge bank area..before entering the fuser assmbly..
# Teflon sleeve not rotation properly due to this paper not passing through it result curl foldings..Replace teflon sleeve..
2. If paper passed fuser assmebly little bit(near about 2-3 inches.
#Problem with paper out sensor/flag. clean sensor, check sensor flag movement & spring.
3. Check registration paper sensor located back side.
# while passing the paper, sensor flag has to act & once paper out it has to reach home,other wise paper jam error will appear.. check flag spring.
Aug 27, 2012 | Office Equipment & Supplies
I have canon copier ir c2100,i cant print becouse when ever i try printing it displays as out of paper but there is a lot of paper too what do i do
Try to put paper into the manual feed tray and let it print. I would check to see what you default tray is set to... It may be to the manual feed tray and make sure you have the correct paper size for your paper trays
May 16, 2011 | Canon for IMAGERUNNER C2020 C2050 C2058...
My canon iR 2022 is displacing the world System Error E007. If you put a paper, it also jams. What to do please ?
Canon fuser technology is hp laser printer system.This copier has a fuser film or eleventh cover.Some times its torn or short then this machine say E007.Its an error code.When occurred this E007 you should defective film.
Feb 14, 2011 | Canon iR 2022 Printer
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
OKI c3200 Laser Printer...
There are 3 little black and white rollers under the cover on the back of the printer. They are pushed under the upper rollers. They should be on the outside of the upper rollers. Somehow they got wedged under the upper rollers. This should fix the accordian paper jam.
Apr 07, 2008 | OKI C3200n Led Printer
104 people viewed this question
jasbo
jasbo
