FixYa.com
Tags:
Van Dyke Technologies SecureCRT for PC
Unknown connection protocol for default or...
posted by Loriick on May 22, 2008
I get this when I try to launch securecrt unknown connection protocol for default or autosession
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 28, 2008
Not Rated (0)
daverh
Rank:Wiz Wiz
Rating: 81%, 50 votes
Assuming you can get past that error message:
  • go to the Options menu, then Global Options
  • Click on the + to the left of Options to open the item
  • Click on Default Session
  • Uncheck the box "Use auto session
  • Click on OK
If you can't get past that message, uninstall SecureCRT and re-install it - it sounds as though some of it's configuration data has got corrupted. If you are comfortable doing this, use Windows Explorer, make hidden files & folders visible and then go to
C:\Documents and settings\your-user-name.
For all the following, ensure SecureCT is not running - even in the System Tray.
Look for the SecuerCRT folder in Application Data and Local Settings\Application Data (I can't remember which one it's in offhand). In that folder, there's a folder called Config. Assuming that you don't have a load of connections set up that you don't want to lose, delete the whole folder. SecureCRT will ask you where to re-create it next time it starts.
It's also possible to delete do it this way:
  • in the Config folder, edit global.ini with notepad.
  • Find the line that starts "S:"Auto Session Name"="
  • Delete the whole line
  • Save and close the file
  • Restart SecureCRT
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Internet and Communication Software problems?
GSM problems
Solving problems with GSM... Answer This...
yahoo msn down load
my yahoo msn is not down... Answer This...
Mobile browser for Sony...
Please give me the link where i... Answer This...
Friendster Prob!
Hi, im neo. id like to ask if... Answer This...
v3i software
any way to get a free v3i... Answer This...
Repair Service
Find Internet and Com. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
