Question about Lexmark X75 All-In-One InkJet Printer
Blinking lights on a Lexmark X75
Hi! Whta could be the problem on my Lexmark X75? As soon as I connect it to the power, the two lights on the front panel start to blink.
  • lobillo May 22, 2008
    I did took the ink but out now the printer do anything. It doesn't feed the paper..Anything else to try?
No. I haven't solved yet. I took the black ink and the blinking lights goes off but the printer doesn't feed or print a test page. It only Scan
Posted on May 23, 2008
  • 56 Answers
Try taking out the the inks. then try to print then replace one at a time.
Posted on May 22, 2008
Am look for printer cord for an lexmark x75
I had that same Problem. I need the Power Cord, and Power Supply, that came with it. I called Lexmark, told them what I needed, and I receivec it, within two days.
I also needed the USB Cable, that connects to the computer. I found that at "Amazon.com." very cheap.
Oct 05, 2010 | Lexmark X75 All-In-One InkJet Printer
I need a power supply cord for lexmark x75
Hello. Lexmark can better assist you with your request for the power supply cord for your Lexmark X75. You can contact them at 1-800-LEXMARK (1-800-539-6275).
Apr 07, 2010 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 all in one. Started with communications device error. could not print. went through troubleshooting-still wouldn't print. started printing randomly(not initiated by me). Couldn't clear print...
Hi. That's quite a problem you have there. Have your attention first on the power supply. It does get hot but it's unusual if it gets very hot. Take out the power supply (the black box behind the printer where the power cord is attached). Check the power specifications. Most of the Lexmark power supply has input ranging from 120-240 Volts and an output of 30 Volts. Make sure you're plugging it in the right voltage range. Check if you're using power surge protectors or power strip, disconnect it and plug directly into a properly grounded wall outlet. Power surge protectors can also draw power away from the printer. When everything's well, try printing again. Hope this helps.
Mar 18, 2010 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 won't work
Contact the dealer since this still under warranty.
Aug 13, 2009 | Lexmark X75 All-In-One InkJet Printer
Status light flashing -- no communication with the printer
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
May 26, 2009 | Lexmark X75 MF All-In-One InkJet Printer
My Power button is flashing and the status.
Well the issue might be with the cartridges or the printer itself.however, please remove the cartridges from the printer and check whether the light is blinking. If the light is blinking then the issue may be with printer hardware. If the light does not blink, then try installing one cartridge at a time and check on which cartridge instaling does the light blink.
Apr 03, 2009 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 printer/scanner
This printer/scanner, hooks up to the computer via USB. The USB cable goes into the back of the printer on the right hand side (opposite side from the power supply). The status blinking could indicate either; 1. No paper 2. No or very little, ink.
May 25, 2008 | Lexmark X75 MF All-In-One InkJet Printer
Connecting my lexmark x75 vista
Welcome to the world of Vista.
Lexmark do not, as yet, have drivers listed on their site for Vista and the x75. You may get away with the xp driver.
Dec 26, 2007 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 All-In-One InkJet Printer Logo
149 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
