Question about HP LaserJet 1020 Printer
I get shadowing while printing.
The shadow is approx 10cm below the print, I have turned down the ink darkness to no effect, is it the corona wire? if so where is it? or do I just need to replace the ink cartridge.
Thanks
  • 300 Answers
The corona wire is incorparated in the toner cartridge. With this problem i would replace the cartridge.
Posted on May 22, 2008
Why do I get bleed through printing on page.
You didn't use HP ink and/or recycled paper is in your printer. Also check that dark/heavy ink is not selected on printer setup on the computer.
Jul 29, 2014 | HP LaserJet 3050 All-In-One Printer
2007 Honda VT 750 Shadow instrument cluster lost power
Hi, Anonymous if some or all of your instrument cluster goes dark/blank immediately upon startup or a few minutes later riding down the road the usual suspects are:
1. Blown instrument fuse.
2. A bad ground in the instrument circuit.
3. Faulty wiring before or after the fuse.
4. Faulty wiring or connector between the fuse and the instrument cluster.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
U0155 Lost Communication with Instrument Panel Control IPC Modulevar...
Honda shadow ace Vt750c 98 03 speedometer repair
Honda VT750C2 Shadow Spirit Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C2 Owner Manual
Sep 30, 2013 | 2007 Honda VT 750 Shadow
2002 Honda VT 750 C2 Shadow no lights come on when the ignition switch is turned on
Hi, Gary if some or all of your instrument cluster goes dark/blank immediately upon startup or a few minutes later riding down the road the usual suspects are:
VT 750 has no electrical power
Honda shadow fuse box
Honda 1998 VT750C Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Nov 10, 2011 | 2002 Honda VT 750 C2 Shadow
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
Epson Stylus Photo 1400 Prints Dark Shadows Red!
Did you use Epson Genuine Cartridges? ????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE
BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 15, 2010 | Epson Stylus Photo 1400 Printer
Was printing photos all was ok then printer stoped printing black
There are 4 inks, cyan, magenta, yellow, and black. When the black runs out, you are left with sort of a dark purple or brown color.
Oct 03, 2009 | Canon I900D InkJet Photo Printer
MINOLTA QMS magicolor 3100 printer, repeat shadowing
Рthe rechagin corona in imije unit is demeged change it
Mar 12, 2009 | Office Equipment & Supplies
Print problems with brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 12, 2008 | Brother MFC-8860DN Printer
Double prints or Text shadow printing by MFC 420CN
yes. you have to run the alignment feature. press ink - set - arrow-down til alignment. After alignment test print read the paper and choose the right setting by nr.
Apr 09, 2008 | Brother MFC 420CN All-In-One InkJet...
HP LaserJet 1020 Printer Logo
187 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
