Question about Video Game Consoles & Games
Xbox 360 will not come on flashing red light on the off/on switch
  • 56 Answers
If its three red lights its hardware failure. Just google "RROD fix" and you can get a step by step guide to fix it yourself. Hope this helps
Posted on May 22, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Switchs on comes up with e74.has 1 red light flashing on front f unit
XBOX 360 Red Light error, or Red ring of Death RORD is a very common issue, and can happen anytime. There are different Error numbers related to RoRD, and appears on screen starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console. Please feel free to message me if you need further assistance
click here to download.....................
Oct 14, 2010 | Microsoft Xbox 360 Console
Red light flashes sometimes and not reading disks
Hi carla 0166,
Its not good news im afraid, that red light that flashes on the console is also known as the "ring of death".if one segment is red its not too bad but if its any more it wont work.
To get around this as daft as it sounds you need to overheat the xbox 360.
i know this as it has happened to me also.
simply switch the x box 360 on and then wrap a towel around it and leave for 30mins.
this will overheat the console and when switched back the red light should be gone.
I hope this has helped :)
Sep 18, 2009 | Sega The Club - Xbox360 for XBox 360
Well when I turn on my xbox 360 the third part flashes red.
hello.
CAUSE The three flashing red lights may indicate that your Xbox 360 console has experienced a hardware failure. Please read the letter that discusses warranty changes for three flashing red light hardware failures.
MORE INFORMATION
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue:
1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles:
906101 Xbox 360: The power supply light is red 906102 Xbox 360: The power supply light is orange 906103 Xbox 360: The power supply light is not illuminated
2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again. If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support, and then click Console Repair in the upper-right section of the Web page.
Note: The online console repair service is currently not available in all countries or regions.
If you would rather contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact for information about how to do this.
APPLIES TO
* Microsoft XBox 360 Video Game System
* Microsoft Xbox 360 Hard Drive (20 GB)
* Microsoft Xbox
Apr 27, 2009 | Microsoft Xbox 360 Console
I soldered ana chip & tightened gpu chip. after switching on the set green light appeared for 5/6 sec. changing to 2 red lights. 2nd time only red lights came . Now it's not turning on.
1. Let your Xbox 360 console cool. You may have to wait several hours for your Xbox 360 console to cool enough. Don't turn on your Xbox 360 console when the console is hot. 2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating. For more information about ventilation, see the "More Information" section. 3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
Mar 10, 2009 | Microsoft Xbox 360 Console
Red lights flashing
3 Red lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Dec 25, 2008 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
Sep 05, 2008 | Video Game Consoles & Games
Video Game Consoles & Games Logo
21 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
