Back to:
Tags:
ASUS Asus P5K Deluxe/WiFi-AP, iP35, S 775, PCI-E , DDR2 1066/667/800, SATA II, SATA RAID, ATX Motherboard
Powering up
posted by Video2 on May 22, 2008
I have an ASUS P5K3 Deluxe WiFI-AP motherboard, it is installed inside an Antec Titan 650 Server case. All parts are brand new. I cannot get the system to power up. I have a question about the motherboard power connection. Part of the connection plug on the motherboard (4) is covered by a black plastic cover. I don't know where to plug in the 8 pin connector.
Please help!
Donnie Martindale
keepsakevisuals@charter.net
817-237-9955
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 23, 2008
Not Rated (0)
NetSalem
Rank:Wiz Wiz
Rating: 84%, 30 votes
You need to remove the cap from 8-pin EATX12V connector and connect 8-pin EPC +12V power plug from your P/S, otherwise it will not work. Your power supply should support 8-pin EATX12V. If you P/S comes with 4-pin connector only you just use your 4-pin open spot and leave the cap on.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Powering up:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
Motherboards
i have msi p45 platinum MB,two graphics cards xfx 9600GT...
Motherboards
I took apart my sister's computer an XP and I'm having a...
Motherboards
hey i need help with my problem that im haveing with my...
ASUS Asus P5K Deluxe/WiFi-AP, iP35, S 775,...
I have a p5k mobo running vista 32 bit and a E8400 CPU....
I was able to connenct to a PC tv screen but subsequently...
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
