Question about HP LaserJet 1020 Printer
Dots when Printing
There are dots on the side of the paper when it prints?
  • 2 more comments
  • nicoleg86 May 22, 2008
    My printer is printing out dots on the right side of the page?
  • Anonymous Jun 04, 2008
    the printer is still not printing after replacing the cartridge with a new one
  • Anonymous Jun 05, 2008
    Dotted Lines appear at printed right side of the paper
  • paAuctioneer Jun 07, 2008
    I have the Dot thing to
Documents containing graphics whether they be spreadsheets or pdf's all seem to print dots along the side, removing the graphics, stops the dots from printing.
Posted on Jun 20, 2008
Replace toner then you cam make sure wether problem with toner or printer.
Posted on May 30, 2008
3 Suggested Answers
  • 186 Answers
SOURCE: HP Laserjet 1320 - Gray bars printing on sides of paper with dark dots
It sounds like a defective toner cartridge. Try replacing it. If that does not cure the problem, then the fuser assembly needs to be replaced, in which case it is probably cheaper to buy a new one.
Good luck
John
Posted on Dec 31, 2007
domagojhrzic
SOURCE: Black dots printing on right side of page
have the same problem cant figure out the solution
Posted on Dec 16, 2013
I'm printing in high quality on glossy II paper and the printing is fine but it looks like the photo is made of dots. if you look closely you can see dots. thanks!
Haha Sorry to laugh but all printing is done in dots... my guess is the print quality is turned way down like maybe 300dpi x 300dpi o btw dpi is dots per inch so basically just need to checkout the printer properties and turn up the quality or dpi
Oct 13, 2013 | Canon PIXMA iP5300 InkJet Photo Printer
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
Black dots are printing on the left hand side of the page when I print from my hp laserjet 1015. Any ideas how to fix this?
Run a "half test". Put paper in the manual feed tray. Print anything. Watch the paper, when it feeds about 1/2 way into the printer, open the cover. Pull out the toner and look down at the paper. If it has the dots, replace the toner. If it doesn't have dots, the fuser is probably bad.
Aug 31, 2011 | HP LaserJet 1018 Printer
Printing with 6 black dots on right side
If the spacing between dots are the same, then you have a dirty or bad roller. If you never had this problem prior to installing the new toner cartridge, then I would suspect you have a bad one. Try a different toner.
Nov 18, 2008 | HP LaserJet 2420 Printer
Printer prints a colour dot at every pages edges
Hi ,
if u get red dots on print it may be problem with Red cartridge Lick age please check u r printer with Ok cartridge .if same problem with new cartridge then u need to clean Mirror built in lance assembly
Jul 11, 2008 | HP LaserJet 3800dn Printer
Printing problem
the problem exclusive between the drum or the fusser unit
Apr 25, 2008 | HP LaserJet 2550L Printer
Printing dots on Brother HL 4040CN
do this procedure
1.print test page then stop the printer on the middle print proses by turn the printer of or open the rear cover
2.remove the paper jam carefully
3.look to the paper if the problem found change the drum unit els the fusser unit cause the problem
Apr 01, 2008 | Brother HL 1440 Laser Printer
Landscape print gives dots or lines in the upper margin
unplog your printer.clean your printhead of the printer by a tissue paper.
Feb 03, 2008 | HP PSC 1510 All-In-One InkJet Printer
Good luck
John
Dec 31, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1020 Printer Logo
440 people viewed this question
Ben Johnson
