Question about HP LaserJet 3050 All-In-One Printer
I cant scan...
Got the error that when I hit scan that it was not set up on the PC can you help ?
  • Dickster46 Jun 03, 2008
    Ive decided that I'll keep the 3505 but it will never be a scanner. Noone has been able to help at HP. Keep getting "waiting for PC" messages and not able to set up the scanner. Software loops. Horrible product support.
Before scanning an error message (cannot be initialized,check power cord)
Posted on May 24, 2008
All i keep seeing is disk error occurred press ctrl+alt+del to restart then press f2 for set up
On Booting Try Enter Bios Setup F10, F2 or Delete for Old PC or Google how to enter Bios if u cant.. Look for disk scan or disk Diagnostic. After full scan if error still showing then replace the DISK.
Mar 25, 2016 | Gateway LT Series LT4010U Intel Atom N2600...
Why doesn't wireless scanning work if initiated from the PC or from the MF212w printer?
hi . I'm almost sure that the toolbox only work on USB. for network scanning there is another aplication I thin is color network scan gear
Mar 14, 2016 | Canon imageCLASS MF212w Network-Ready...
Scan errors
You nee the complete driver for the printer....the scanner driver and software must not be loaded..try to reinstall the driver with the scanner driver should work than......keep me posted if you still have the problem
Nov 27, 2011 | HP LaserJet 3050 All-In-One Printer
Error: windows explorer encounter an error and must shut down. Happens in Microoft Word, trying to get properties of printer. does not happen in internet explorer or running antivirus scan or malware...
Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files. use reginout cleaner to easily fix it
Oct 16, 2010 | Microsoft Windows XP Home Edition for PC
My Officejet Pro 8500 won't scan, says "no scan options"
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 23, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Im trying to scan and the canon says: "set the pc to start scan"...? Nothing pops up on the computer, what do i need to do?
I'm using an MG5220 and got this same message. Here's how I fixed it.
On the printer control panel press the soft key to select the scan function. Then hit the soft key to select Save/Forward. Then select Foward scanned data to a PC. On the next screen make sure to select the appropriate PC. In my case I'm connected wireless but the selection was set to USB connection and that's why I was getting the error noted above. When I picked the PC that is connected wirelessly everything worked fine again.
Jul 12, 2009 | Canon PIXMA MX850 Multifunction Printer
My Dell Dimension 8200 PC keeps re booting itself once it gets to the home page. i cant even hit the start button cause it restarts itself that fast! please help
As soon as u see the black screen...hit F8 repeatedly to get it into Safe Mode.....then go to system restore and reboot/restore system back on a saved day. Then run your virus protection and scan for malware. This should get you back online. You may need a full system scan to locate the effected DLL's anmd killl off your intruder.
Jun 23, 2009 | Dell Dimension 8200 PC Desktop
Cant scan??
if installed right it should bring up the program on computer when you change printer to scan and hit start. should be able to select computer on scanner after you switch function to scan on printer.
May 21, 2009 | Brother Multi-Function Center MFC-240C...
Missing shell32.dll file
Go to your bios and make the cd rom the first boot disk.
To get into the bios, usually del key when booting gets you in.
Once you boot from the xp disk, follow the prompts until you get to the screen to hit f8, on the next screen hit R and the system will do a repair with out changing any of your settings.
Be sure to go to Microsoft and run the XP updates.
Mar 13, 2009 | HP Compaq nx6110 PC Laptop
CX6600 SCANNER
Download the Reference guide for your machine from th eEpson web site. It will inform you what you need to do to complete the scanning options. you can also download the Epson Scan utility to help with scanning to email etc.
Jun 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
HP LaserJet 3050 All-In-One Printer Logo
60 people viewed this question
Ben Johnson
