Question about ViewSonic PJ402D DLP Projector
DIY lamp I hook a 110V 100W bulb to the pj402d. It lit up for 5 sec. then it turned off. No damage was done to the bulb or projector. Is there a cheap way to replace the bulb with something else? There must be a modification to the sensor circuit that will allow a substitute bulb to operate properly.
  • 56 Answers
I had the same problem awhile back and looking around for an answer i found this.
http://recklessphilosophers.com/2008/05/02/home-theatre-for-63--dlp-pj-retrofit-for-7-bulb-instead-of-300.aspx
Posted on May 22, 2008
Lamp light flashes amber without the lamp ever turning on, then projector shuts down in a minute or two
Based on what you're describing, it sounds like a failure in the lamp ballast itself. The projector will probably need to be sent for service.
If you have a spare lamp, that would be the first thing to try. However, if it isn't that, it is likely the ballast.
Mar 15, 2016 | ViewSonic PJ402D DLP Projector
Epson 7800P projector?
Please dont use cheap alternative Lamp Bulbs in Epson. There are issues where the cheap Bulbs draw more current and damaging the circuit board.
Apr 22, 2014 | Office Equipment & Supplies
I have a 3M 1700 Overhead Projector. After about two months of use, my bulb stopped working, so I replaced it with a new bulb. When I turned on the projector, there was a slight "pop" and the...
Take the lamp out and check for physical damage. Some lamps come defective and can shad (brake glass inside) upon warming up. The "pop" sound could be it.
Feb 12, 2011 | Office Equipment & Supplies
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
I have a Canon LV-7350 that comes on for 15 secs then turns off.. everything is hooked up correctly. and I have swiched out the bulb to rule that out.. anyone ever seen this?
Hello :
It must be overheating problem . Check the fans . If the fans run properly , then you need to check the fuse or the power PCB [printed circuit board ] . If everything is okay with all of those , then I recommend you to replace the bulb .
Here I'll tell you how to replace it :
  1. Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
    It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
  2. In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
  3. Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
    Please note that in some projectors a small inside filter should also be replaced.
  4. Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
    Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
  5. Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
Warning:
  • avoid touching the bare projector lamp
please rate !.
Apr 12, 2010 | Canon LV 7350 Multimedia Projector
Projector shut off
Your lamp may well have died..
Oct 07, 2009 | ViewSonic PJ402D DLP Projector
SP-LAMP-LP3E powers off in 5-20 secs after inital power on
if the new lamp doesn't have a problem, then it's not the ballast, it's just a bad bulb. especially if you didn't get it from infocus. the cheaper lamps don't last long. you get what you pay for.
Dec 23, 2008 | InFocus Projector Lamp for LP340, LP340B,...
Resetting lamp on a lg rd jt40 projector
remove bulb. replace bulb. within ten minutes press exit on projector and hold for three secs. then immediately press menu then press left or right arrow button. you are done. turn off then turn on
Jul 04, 2008 | LG RD-JT40 Multimedia Projector
Replacing bulb
hold the volume up/down in ,switch unit on while holding these in for 30 secs, if that fails, flash unit with new software.
Dec 01, 2007 | InFocus In Focus SP-LAMP-021 Replacement...
ViewSonic PJ402D DLP Projector Logo
632 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
