Jam in output bin - duplex area Error message
Jam
in output bin
alternates
with
Open
door and clear jam Description
Paper
jam in duplex reversing area Action
Clear the jam.
Press the (SELECT) button on
the control panel.
If the problem continues,
contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came
in the printer box for additional contact information.
Jam in output bin - fuser area Error message
Jam
in output bin
alternates
with
Open
A
paper jam has occurred in the output bin near the fuser area. Action
Clear the jam.
the control panel.
Just try the steps
Jam in output bin - fuser areaError messageJam in output binalternates withOpen door and clear jam
DescriptionA paper jam has occurred in the output bin near the fuser area.
Action
Clear the jam.
Press the (SELECT) button on the control panel.
Jam in output bin - duplex areaError messageJam in output binalternates withOpen door and clear jam
DescriptionPaper jam in duplex reversing area
Action
Clear the jam.
Press the (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Don't know if you solved this alread, but take a look at the 'exit flag' located just where the paper is spit out of the printer. If the exit flag is in the "up" position, just bring it down and that should solve the problem. If the exit flag is in the up position, this makes the printer think that the bin is full. Hope this helps. Either that or http://support.lexmark.com
I had the same problem and it was driving me nuts. Turns out it was nothing more than the little flap that hangs down at the left hand corner of the output tray. It was stuck in the up position. After resetting it I had to cycle the power and everything is copacetic. Hope that helps
It appears that this means that the printer thinks the output tray (on top of the printer) is full. If it is not, then the signal arm may be out of place. Here is a relevant article.... http://support.lexmark.com/perl/support/support.cgi
