Question about Microsoft Xbox 360 Console
E74 what can i do? i have the xbox taken apart as of now
    President:
  • 4,402 Answers
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Posted on May 22, 2008
How do I repair the E74 error on the xbox 360
E74 - This error is caused by a cold solder joint under the GPU, (H)ANA-chip or in between. Mostly it is one of the outer solder balls on the side facing the (H)ANA chip so a shim increases the chanced of success quite a bit. Can also be a component that is missing or damaged so look for missing parts near the GPU and the (H)ANA chip. Xbox 360 Error Codes Explained and How to Fix Them
Aug 13, 2015 | Microsoft Xbox 360 Console
On the circle 1 part red says systemm error e74
You are experiencing a hardware failure, better know as the red ring of death. Microsoft recomends the following
Step 1: Confirm the E74 error loadTOCNode(2, 'moreinformation'); To verify that your console is displaying the E74 error message, follow these steps:
  1. Turn off the console.
  2. Turn on the console.
  3. Verify that your console displays the E74 error message.
Step 2: Submit a console repair request loadTOCNode(2, 'moreinformation'); If you are experiencing this problem, your Xbox 360 console must be repaired at our service center.
Start the repair process online. (http://service.xbox.com/)
For more information about how to contact Xbox Support directly, please visit the following website: www.xbox.com/support/contact (http://www.xbox.com/support/contact) Microsoft covers repairs for the E74 error for a period of three (3) years from the original purchase date of the console. If you are outside the initial three-year warranty period, you can still receive console repair service from Microsoft for a fee for the E74 error. For more information about the E74 warranty extension, see the following article: 969905 (http://support.microsoft.com/kb/969905/ ) About the E74 warranty extension for Xbox 360 consoles
Jul 30, 2011 | Microsoft Xbox 360 Console
What does error code e74 mean for the x-box 360
The e74 Xbox error's principal cause is overheating, due to excess heat causing damage to various components, and eventually major malfunctions in the hardware of your console. Why is this heat able to build up and cause damage that leads to the Xbox 360 e74 error? This is actually due to cramped case design and a lack of cooling devices such as fans and heat sinks. Although overheating is ususally a problem for all electronic devices, the Xbox 360 does seem to suffer particularly badly from this issue. unless you have a bit of technical knowledge than the best thing would be to A) fix your Xbox e74 problem by sending your Xbox 360 back to Microsoft for repair or B) buy a new one. there is no easy way to permentaly fix it without taking your xbox apart and the "towel trick" which is where you wrap your xbox in a towell power on until it overheats and shutsdown is only a temporary fix and will cause major damage to your xbox in the long run. fixing yourself consists of stabilizing the heat shields by removing the old brackets and replacing them with new heat paste and bolts so the best thing if you are dedicated to doing it yourself would be to probably buy a manual online. you shouldnt need to pay anything over $30 and make sure you get a full manual because alot of them only deal with the "red ring of death" (which is three red rings)
hope this helps
Dec 02, 2010 | Video Game Consoles & Games
How to fix error message e74 with one red ring flashing
hope this helps
Dec 01, 2010 | Video Game Consoles & Games
E74 problem with xbox
hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
ANOTHER BROKEN XBOX 360
replace heat pads they are so cheap. wrap pennies in electrical tape and put it on were the heat pads were. use Heat Sink to glue it on
Oct 01, 2009 | Microsoft Video Game Consoles & Games
Xbox 360 will not turn on after e74
You might want to have a repair technician take a look at it. The chips might need to be reflowed and the x-clamp replaced.
Apr 05, 2009 | Microsoft Xbox Console
Error e74
Try using a new AV lead as that could be at fault.
check the pins inside the AV plug and socket on the back of the xbox 360 console to make sure there are no bent pins.
if all that fails the video controller chip on the PCB will need to be resoldered or replaced, i think microsoft can fix this under their 3 year extended guarantee.
jonno
Sep 03, 2008 | Microsoft Xbox 360 Console
Xbox 360 e74 system error
E74 is NOT caused by a bad AV cable, it is NOT caused by the ANA/HANA scaler chip. It is the solder points on the GPU that have cracked. You must use a heat gun and do the XCLAMP to fix it. Shops normally charge $75-100 to fix that.
May 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
73 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
