Question about Microwave Ovens
Panasonic microwave start button
Hi
I have a Panasonic microwave (NN-T695SF) which is just about 2 years old. Suddenly yesterday it's start button has stopped functioning. All the other buttons seem to work but the start button. Please help!
Meenal
  • 3 more comments
  • MS-EDM May 24, 2008
    Thanks, atleast I think I know the problem now. If I could open the screws of the outer body then I would have looked inside. However, it looks like I will need to get this to a technician. Thanks a lot.
    Regards
    Meenal
  • Dauber85 Jun 14, 2008
    All button but the start button appear to work. Took it apart, tested the switches, there was continuity on both switchs, so it could be the board, but where do I get a price and availability on such a thing?
  • Anonymous Mar 14, 2014
    My microwave is in Chinese I need English
  • Anonymous Mar 15, 2014
    Just installed a new magnetron because microwave was not heating food. Now that magnetron is installed the START button does not work?
  • Anonymous Mar 16, 2014
    The microwave function stop working
  • 525 Answers
You may have a sticky door switch. Try a simple "slamming" of the door, don't over do it, just a little harder than normal. This may help pop the plunger in the switch back up. The switch could have also become loose and moved out of its adjustment.
If this does not help, a technician should save you time and money with this sometimes perplexing problem.
Posted on May 24, 2008
  • Microwave Ovens Master
  • 8,864 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel or keypad.
Ovens are designed (like dryers) so they don't run with the door open.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
I have almost the same problem as glen except for mine not starting at all. It was working properly until today. i removed the plug then pressed the reset button as what i have been advised by the customer...
That sounds like the Magnetron/Invertor has failed and taken out the mains fuse.
The Invertor is not user serviceable.
Call an authorised repair department.
Feb 14, 2011 | Panasonic NN-T695SF Microwave Oven
Panasonic Counter top Microwave model # NNT695SF Often when I push the start button, the microwave will go for a few seconds and then cut out. I then open the door and then shut the door and push the...
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
Sep 30, 2010 | Panasonic NN-T695SF Microwave Oven
Hi, I have a Panasonic Inverter microwave NN-Sn9688. It's less than a year old and when you press the START button H98 appears and it will not start. Everything else works, clock etc and reset/stop...
Hi Judith, I am Kelly
If this has a 1 year warranty it is time to make that call.
Otherwise see this link about H97 or H98 codes: http://www.applianceaid.com/micro_faultcodes.html#panasonic
There are a few things that can cause the problem, none of them cheap repairs. The Magnetron filament, Control board and Inverter are the top 3 other than a losse connection.
I tried running the Model number NN-SN9688 and it does not cross. See Panasonic link here: http://www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd?N=779832097&Ne=&No=0&Nr=12001&Ns=&Ntk=SupportSearch&URL=vSupportSearch&cmTag=true&catalogId=11017&storeId=15001&cm_sp=SiteSearch-_-SupportSearch-_-SupportHome&Ntt=NN-SN9688&x=28&y=20
I did not go to Panasonic Global and try other countries. I just did a USA search.
Thanks for choosing FixYa.
Kelly
Sep 10, 2010 | Panasonic Microwave Ovens
It is actually NN-T695SF, it will not warm food. It powers up then goes dim, then powers up then goes dim, it keeps doing that. Food comes out cold.
Hi, if it is an inverter microwave and the problem is cycling every 2-3 seconds, my experience is the magnetron has most likely gone short circuit and the inverter board is shutting down to protect itself and then restarting, hence your symptom.
DO NOT try to test this unless you are experienced with extra high voltages - the voltages present/stored in a microwave even when powered off can kill you.
Aug 13, 2010 | Panasonic NN-T694SF Microwave Oven
My NN-T695 Panasonic microwave oven starts up for two seconds then cuts out before doing any warming?
I'm having the same problem with the same model microwave. It has taken hard use for a long time, but now it will (sometimes) start and then stop after a second or two. I think it's a loose connection, because a couple of times I got it to work by rapping on the back or side.
Mar 02, 2010 | Panasonic NN-T695SF Microwave Oven
Microwave stopped working suddenly,the sreen reads H97
If your oven is out of warranty then i would suggest just getting a new one.
The code is for a bad controller circuit, and it would cost almost as much to fix it as it would to buy a new one.
Jan 12, 2010 | Panasonic NN-H275 Microwave Oven
Buttons not responding on nn-s235
My microwave nn- s235 have the same problem only stop botton waork but no child is displayed in the display
Jun 14, 2009 | Panasonic Microwave Ovens
PANASONIC MICROWAVE NN-K657
To UNLOCK it, press Stop/Clear 3 times.
To LOCK it, press Start 3 times.
You can download your owner's manual here:
http://techdocs.panasonic.co.uk/GetDoc.aspx?did=125787&fmt=pdf&lang=en&src=3
Feb 24, 2008 | Microwave Ovens
Microwave Ovens Logo
1,448 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
