FixYa.com
Toshiba 27D46 27
No picture (by 3 users)
posted by mikey33 on May 22, 2008
has no picture with a line through the middle of the screen. it's not that old feb 2006.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on May 30, 2008
I have a black screen and a thin white line across the middle of the screen, and it won't go away. I can't see anything. The sound is okay, but the picture is horrible
Comment by animail, posted on May 29, 2008
I'm having the same problem with my Toshiba (which was purchased in March 2006).  We'll be watching a show or movie and the picture will blink out and turn in to a thin horizontal line across the middle of the screen.  The normal picture usually comes back within 20 seconds to two minutes, or by turning the television on and off.  Is this a problem with the picture tube (the two year warranty just expired)?
Solution #1
posted on Jul 13, 2008
Not Rated (0)
robotek
Rank:Guru Guru
Rating: 90%, 505 votes
Hi
Your set will have cracked solder joints in and about the vertical output stages. This is not a major repair, and will require re-soldering of that stage, and maybe a few capacitors replaced as a cursory repair as preventative maintenance. should cost between $50-80 depending on who you get to look at it. If you are quoted a price higher than this, I suggest ringing around repair guys in your area and be careful to explain exactly what you have described the fault as here.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Standard Televisions problems?
36inch Sony Wega KV-36HS420...
The TV will turn on I will hear... Answer This...
Toshiba 27D46 27" TV
volumr
the volume keeps turning itself... Answer This...
no power
TV was off or I guess in sleep... Answer This...
no power
it will not power on the red... Answer This...
doesn't stay on
Power come on and off RCA... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
