Black oil or grease on clothes after washing
My washing is coming out of the machine with black marks over the clothes. They are small black speckles and look like oil marks as they do not wash out. Do you have any idea what is causing this as it is happeing on a regular occurence now.
  • 3 more comments
  • LAUABB May 25, 2008
    what is the boot?
  • Anonymous Jun 14, 2008
    We wiped down the "boot" of our front loader, but still gave the black marks
    Not on all the clothes. It almost seems like it happens in the spin cycle
  • Dene Hines
    Dene Hines Jul 10, 2008
    washing has black marks on it which looks like oil or grease. I have put the washer on a boil wash with soda crystals - cleaned the boot as you call it and it still gives me clothes with black marks on them after a wash.
  • lindakb1 Jan 22, 2009
    black marks on clothes
    I have washed and cleaned the washer including the boot.
    the dots and streaks,smudges appear on some loads not all.
    there is on noise when I spin the tub
  • TRDurham9 Apr 27, 2009
    I have the same problem. However, I have top load washer. I've had a service guy check it out and he just scratched his head. I feel like I have disposible clothes anymore. The thing is if I buy a new washer and it still happens then I just spent a lot of money for nothing...I want to make sure that this problem is that washer.
    Novelist:
  • 177 Answers
Is you machine a top loader or front loader? if its a front loader the black marks could be from the boot. WIpe the boot with a good cleaner. and try not to over load machine. and if it a top loader your transmission is probably leaking oil back into clothes tub. You could have it rebuilt $$$ or better replace the machine.
Posted on May 24, 2008
  • Terry Schneider May 26, 2008
    We call it a boot even though it doesnt look like a boot at all sorry,
    Its the rubber flexible piece that goes from the front panel to inner basket. The door seals against it.
    I assume you have a frontloader? this boot maybe black, or gray in color.
    Again if you overload you machine, your wash items will rub up against this boot and leave black marks. Use a liquid dishwashing detergent like Dawn and some elbow grease and the marks should come out, unless of course the item is damaged
Loud noise when spinning black marks on clothes leaves drum circle marks on clothes
it sounds like the bearings have gone ...are the marks on clothes oil marks ? or grease marks ? this is a sign of bearings. if there rubber marks it will be your door seal thats gone ( dose it leak )
May 05, 2015 | Beko Washing Machines
OIL STAIN ON A CLOTHES out of washing machine E12477
Are they getting the oil stain from the washing machine? If so, you need to get a tech out to inspect your washing machine. If you are putting oily clothes into the washing machine hoping it will come out, it's too late, you need to pre-wash with Shout or Tide to remove oils and grease. The more you wash and dry it the deeper the stain will set. Sounds like you need to throw those clothes away.
Jan 20, 2015 | Washing Machines
I get black marks like a crayon or ink line on certain light colored shirts after washing my clothes. Not sure if it's coming from washer or dryer. I use a stain remover and it's not coming out completely.
is the black marks grease look under the bottom of the machine and look on the side walls of the machine if u have a line of grease around both sides then you would need to change the transimission on the machine if it is not grease and you determine that is pen u might try looking in between the two baskets.And lastly ihave seen pen cartriges enlodge inside the pump which does cause the pen to leak hope this helps
Jun 26, 2010 | Washing Machines
Black grease spots on clothes after the wash I have a simpson espirit 750 washing machine
Hi just read your posting.Are you 100% sure the black marks are grease or oil?If you are then the only place the oil comes from is the gearbox.This means that to repair this fault you need a new gearbox.Unfortunately the repair is not cheap so I would recommend getting a service tech out to confirm.Every time I went to a customers house and I saw this problem then I would tell them the same thing.Once again sorry for the bad news and please reply if you need any more help or advice.Good luck.
Jul 11, 2010 | Whirlpool Washing Machines
Gray marks on light colored clothes
That is exactly what it is, grease. It is coming from the transmission past a worn or defective seal usually the transmission will have to be replaced.
Mar 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Marks on clothes
Hi. Souds like an Effect called ****. Usually caused by not using enough powder, or washing at too low a temperature. You should do a boil wash at least once a month with powder in but no clothes in. It is called maintenance wash. Always wash at the recommended temp on the wash care label. Good luck
Nov 19, 2008 | Washing Machines
LG washing machine repair
hiya
is it a rumbling noise? if so it may be the drum bearings are in need of replacing. two tell tale signs are
1, check clothes for any black speckles, as this is a clear indication that the bearing seal is worn and that oil and grease from the bearings are entering the wash tub.
2, whilst the drum is empty see if there is any movement in the drum, the easiest way is to place four fingers inside the lip of the drum and place your thumb on the door seal and pull it towards you in an up and down motion. if there is any movement then the bearings need replaced.
hope this helps
Jul 31, 2008 | Washing Machines
Black marks on clothing
Sounds like grease or oil from transmission may be leaking and finding its way into tub.
Nov 03, 2017 | Kenmore 43142 Front Load Washer
Washing machine problems
Oil or grease due to failing seal on the drum shaft.
Jan 14, 2008 | Washing Machines
Washing Machines Logo
5,359 people viewed this question
Top Washing Machines Experts
