No start, horizontal amp shorted - Televison & Video
  • 8,617 Answers
Whats the model number?
Posted on May 22, 2008
I keep popping 25 amp fuse when trying to start honda GX610 18 hp gas engine on 3100 Stone Wolf pac roller
if the fuse pops when turning to crank position the problem lies within the small solenoid wire to the starter (this wire goes from the ign.switch to the starter solenoid and is powered up when in the start position) this wire is shorted to ground....or the starter solenoid is shorted....best way to tell is unhook wire from solenoid and turn key to start...if the fuse does not pop its the solenoid....do this several times to verify
Oct 05, 2014 | 18 HP V-TWIN GX610 V-Twin OHV Horizontal...
Fbt not working
Check the horizontal output transistor first. If it is shorted, replace both horizontal output transistor & FBT.
Aug 24, 2012 | Daewoo Televison & Video
Vertical line
If this is a CRT TV then the failure of the following must be checked as it is the failure of the horizontal section..
1. check the soldering on the horiozontal coils, the linerity coils and the deflection coils.
2. Failure of the pin-amp section. the linearity section.
3. failure of the horizontal coils.
4. Open reisitors/ shorted or weak capacitors in the sections .
6. Faulty IC - horizontal/deflection circuit/ frequency and drive IC.
Aug 30, 2011 | Televison & Video
21" sony tv horizontal amp short what is the
The most common cause of this symptom, by far, is the loss of vertical deflection amplifier. It usually requires the replacement of the vertical output transistor or some component associated with it. The cost of repair would run around $150 to $200 depending on the exact parts replacement and the shop that does the work.
i hope this will be help full to you .
goodluck
Feb 02, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Turned on tv & it made a crackling noise, so i turned it off & cleaned insice with an air duster. Left it off for a while then turned it back on, it made a low beeping noise.
Not knowing the brand or model number, I would start with the horizontal output transistor and high voltage transformer (both are in the same circuit). When the horizontal output shorts, it puts excesive load on the power supply causing it to chirp or "beep".
Oct 20, 2009 | Televison & Video
Hitachi 60SDX88BA
no picture condition could be caused by a problem in the horizontal deflection circuit or a power supply failure. A horizontal deflection problem often are followed by open fuses due to shorted components such as a h.o. transistor ofcourse there are a lot more componentd that constitute this circuit. Another no picture condition could be caused by defective convergence power amps. these amps usually give an clear indicator when they are about to quit(color curved or missaligned, double color images etc.) this is a common problem with projection tvs and that is where I would tell the tv tech to start looking.
Sep 19, 2009 | Hitachi 60SDX88B 60" Rear Projection...
TV has sound but the screen looks like it is going out has double, colors green, yellow, red. Went off by itself once. Wavy looking. Smelled burning in back, when it went off by itself.
you're describing a power convergence amp problem, usually starts out at random color shdes or gohsts around the images more noticeable on scenes with letters or horizontal and vertical lines. the power amps overheat and sometimes will short out causing the fusible resistors to burn out. these amps are usually mounted on heavy metal dissipation units in one of the main boards.
Jul 30, 2009 | Samsung Televison & Video
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
