Question about Kodak EasyShare CX7330 Digital Camera
Battery Cover Replacement Part for Kodak CX7330
I dropped my camera and the the battery cover broke. When I put the batteries back in and the broken cover to try to get the lens to go in, the camera doesn't work. Do you think that there is more than just replacing the battery cover or should I replace it and see if it works with a new one? Also, any suggestions on where I can buy a replacement? Thanks so much.
  • Anonymous May 24, 2008
    dropped camera,sprung battery lid, won"t stay closed. how much is a new cover
  • franmas12 Jun 01, 2008
    iI DROPPED MY CAMERA TOO I HAVE A REPLACEMENT COVER DOES ANYONE KNOW HOW TO CHANGE THE COVER
I did the same thing. Is the little medal piece still on the inside of the battery cover. If not you will have to replace the entire door and you should be all set.
Posted on Jun 04, 2008
My kodak cx7330 digital camera battery door broken
E-mail your question to this address: http://www.kodak.com/global/en/service/contactKodak/email/consumerDigital_contact.jhtml?pq-path=13452
Jan 09, 2010 | Kodak EasyShare CX7330 Digital Camera
My batterry door is broken I don't know how to put
KODAK doesn't sell battery doors for any of their models.
A repair for this fault is 24,47 pounds + shipping to the repair centre.
If you already have the battery door; I suggest you will have a local camera TECH to attach the door to the unit.
Dec 14, 2009 | Kodak EasyShare C315 Digital Camera
Cybershot DSC-P200 broken battery/memory stick cover
I suggest that you contact Sony PAS to get the new Battery cover at 1-800-488-SONY (7669)
Phone Hours:
Monday to Friday - 8:00 am to 12 am (Midnight) ET
Saturday and Sunday - 9:00 am to 8:00 pm ET
Then, contact the nearest dealer to get the Battery door fixed instead of sending for service.
All you have to do is, press the pin on both the sides of the Battery door and insert in the hole available for battery door on camera.
Sep 26, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Battery Cover Broken
You will need to replace the battery cover assembly and contact Kodak at 1-800-431-7278 during normal business hours (Monday - Friday from 8 a.m. - 5 p.m. EST), and select option 3.
Jun 16, 2008 | Kodak EasyShare C340 Digital Camera
About battery door broken in Kodak CX7330
I've got 16 of these cameras and had to replace the door on 3 of them. (I'm a teacher)
it is quite simple, but there are little tiny screws and some dexterity required!
to replace the battery door, you need a super small screwdriver (I've used both an eyeglass size and the screwdriver that came with my son's tech deck!) . you'll have to unscrew all of the small screws that hold on the back of the camera. remember which screws go to which hole - because some are longer than others. once the screws are out, you'll have to gently pry off the cover. carefully - you dont want to crack the camera case. you'll also want to be careful not to touch the sensor, which will be exposed with the case off.
NEXT you;ll have to pry the little spring out of the battery door to actually remove the old door. you'll probably have to use a screw driver to pull the spring on the new door back enough to fit back into the holes. that's really all there is to it. replace the cover and the screws.
Feb 11, 2008 | Kodak EasyShare CX7330 Digital Camera
How to replace battery cover for Kodak Dx6440
We had the same problem dropping the camera, and ordered a pair of new battery covers. I was able to install this by carefully removing the cover screws and slipping the pins into their slots. I am sure you probably got it by now.
This problem was before the one posted about start and then die. The "expert" response posted was worthless. This whole website seems to be a collection of anecdotal semi-worthless stuff.
Perhaps other topics may contain more relevant valuable commentary.
Sep 16, 2007 | Kodak EasyShare DX6440 Digital Camera
Cx7330, battery cover BROKEN
Remove batteries and memcard. Remove 8 screws, the screws on the bottom are smaller than the side screws. Rear cover will slide off, watch out for loose LCD screen. Two protruding slots on the bottom hold the battery cover hinges. Hold battery cover wide open and at an angle to snap hinges into place. Reinstall rear cover and screws.
May 29, 2007 | Kodak EasyShare CX7330 Digital Camera
Kodak EasyShare CX7330 Digital Camera Logo
145 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
