Question about Frigidaire Dryers
Frigidaire Gas Dryer
My gas dryer's drum is crooked and my clothes are being caught between the drum and the front of the dryer. Is there a way to adjust the drum and make it sit straight?
    President:
  • 1,314 Answers
You need to replace the door glides the felt between the drum and door unplug the drier pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and snap it off then redo the felt kit
Posted on May 22, 2008
Clothes stuck in drum
You might have a drum glide, felt piece, that has come off or unaligned itself from the drum. Contact Frigidaire for one and replace it. You have too much of a gap in the front and that is why your clothing material gets caught.
Jul 29, 2012 | Frigidaire FEQ1442ES Electric Dryer
Clothing getting caught on lint trap tab. And clothing getting caught between drum and front of dryer
Probably has extra space between drum because the front felt guides on the drum have worn. This can be accessed by removing the front panel.
Oct 05, 2010 | Frigidaire Electric Dryer
My dryer is ten years old. A few months ago, some of the clothes would come out with rust stains on them. Some of the clothes would get caught in the seams which would cause staining, tearing and...
I would suggest replacing the front drum bearing. Sounds like the gap is now excessive, obviously allowing clothes to get caught up in there. Drum must be removed from the dryer to do this.
Good luck, hope this helps.
Aug 19, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Clothes caught between drum and top of front panel: Frigidaire
You have a bad tub seal. It is glues onto the front panel...looks like a thick felt pad. Common thing on Frigidaire dryers.
May 21, 2010 | Dryers
Frigidaire FSGC747GE gas dryer is causing spots
you may need to replace the upper and lower drum felts, if they are worn, some of the clothing may be getting caught agains the drum and getting a mark on them. if the mark is like a pencil line mark it will be from the dryer, if it is more like an oil spot it will be from your washer. take a look at #20 & 21 in this picture.you may also need to replace the rear bearing which is #12 in this other picture. hope these help you.
Oct 24, 2009 | Frigidaire Dryers
I'm finding pinholes in my clothing.
I'd be more suspicious of what you're putting through the wash, rather than the machine.
Aug 01, 2009 | Electrolux Frigidaire Affinity AGQ8700FE...
Frigidaire Dryer. Clothes are damaged by either being ripped when caught on dryer drum. Clothes also are marked with hard to remove rub marks.
Open the dryer door. Reach in just inside and feel for the felt seal that goes all of the way around the drum. The culprit is usually the top portion of the seal which supports the end of the drum near the door is worn out. This allows the drum to tip down and leaves a gap at the bottom. Clothes get caught in this gap and get rubbed and marked or rubbed clear through. Remove the front of the dryer and replace the seal. On some models the top 1/3 is replaceable. This portion carries the weight of the drum and is what wears out.
Jun 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
My clothes are getting caught in my dryer.
I am having this same problem with my GE dryer. I found a post on fixitnow.com from a guy that has repaired these for years. He says it is the rear drum bearing. Looks like a pretty easy fix, I am going to try to do it myself. If you try this, I have also read that you should spend the extra $10 to go ahead and replace the drums front felt glide kit.
http://fixitnow.com/2005/03/field-notes-frigidaire-dryer-front.htm
Good Luck!
Mar 25, 2009 | Frigidaire GLER642A Electric Dryer
Dryer Leaving Burn Marks On Clothes
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Oct 09, 2008 | Dryers
Dryers Logo
91 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
