FixYa.com
Tags:
Ultra Linear UL-2200D Car Audio Amplifier
Volfenhag ZX8300 on with radio, off with cd or mp3...
posted by Darryl8784 on May 22, 2008
I just installed this 1200 watt, 4-channel amp with a 1.5 farad capacitor, and 2- 1000 watt Volfenhag subs. I hooked it all up and everything seemed to be good since the subs were pounding with the radio on. I then hooked up my MP3 player to the aux in and the amp and capacitor turned off. I switched back to radio and after a couple of seconds, the amp and cap powered on again. So I tried a cd and the amp and cap powered down again. What gives?
All fuses are good, the ground is nice and tightly connected to a sanded down bare metal surface in trunk and the powere wire looks all good. The system sounds great with the radio, but completely shuts off for cd's and aux-in. Any ideas would be greatly appreciated, I can't seem to find much help anywhere regarding this amp. Thanks!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 22, 2008
Not Rated (0)
pbabin
Rank:Guru Guru
Rating: 89%, 240 votes
You're using the wrong control wire. You're likely using a wire marked antenna control. You need to use the one marked amp control. They are both blue.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Car Amplifiers problems?
Car Amplifiers
wiring installation on Majestic...
need help with installing this... Answer This...
Car Amplifiers
genon avr1601
Hi gud day i have genov avr1601... Answer This...
Car Amplifiers
i need a code for a universal...
code for a remote control... Answer This...
Car Amplifiers
schematic for washburn pg 65 c
need schematic Answer This...
Car Amplifiers
NASHVILLE DAB35
CONECTARE Answer This...
Repair Service
Find Car Amplifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
