Question about Harley Davidson KNG America 026711 Harley-Davidson Fat Boy Replica Phone
New harely just got one. what to do in the next few weeks so the engin will run properly
  • 27 Answers
Take it easy and keep the revs low - don't thrash the arse off it to start with. Easy gear changes and use the clutch well. Change the oils at first 1000 miles. If it is brand new then the dealer should be giving you your first service free under warranty?
Posted on May 23, 2008
Mower starts easily, but runs 10 seconds and quits.
Carburetor needs to be cleaned; main jet is clogged with debris, dirt, whatever.
Jun 23, 2015 | Garden
My 2003 lincoln ls is running hot. It stared about a few weeks ago. it ran hot, and I let it cool off. It ran fine after that. Today, it ran hot. I let it cool for a few hours. When I crunk it up, it...
First check your coolant level.
Next make sure your fan is operating properly.
Lastly, if all of those criteria have been met check your water pump, it may need replaced.
Hope this helps.
Sep 06, 2011 | Ford LTD Cars & Trucks
I have a ryobi rlm140sp, when I release the engine run handle the engine won't stop.. It slows down a little but keeps going.. I have to stop it by push ******* the throttle lever on the carb linkage..
You probably have grass and muck jammed up in the mechanism that engages the Self-propelled wheels. Take the cover off and clean it out. Then lubricate the cable at both ends with any spray lubricant. You may have to lubricate it for the next few days or weeks to get it to start working properly again.
Good Luck!
Jim
Aug 05, 2011 | Garden
Problem keeping engine running on Husqvarna 22HP VT riding mower
Take the fuel bowl off and clean it real good as well clean the fuel jet. It may be the bolt that holds the fuel bowl on. I am not sure. I use my air compressor to blow it out also get a real fine wire and put through the fine hole may help. It does not take very much dirt to make an engine not run right. I repair a lot that way that is not running properly.
Jun 06, 2017 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
2001 Isuzu Rodeo 4WD. CHeck Engine light on and
After market spark plugs could be the problem.
Reinstall the old plugs and see if that fixes it.
This vehicle has an ion sensing ignition system and is real sensitive to the proper spark plugs. I would get the proper plugs from the dealer if the old ones work.
The codes P1311 and P1312 are ion sensing codes.
Sep 23, 2009 | 2001 Isuzu Rodeo
Its hare to turn the wheel.
check check fluid level on power steering pump
Sep 19, 2009 | 1999 Dodge Grand Caravan
1991 Johnsoon 90 HP outboard hard to start, floods after stop
Hi, You did a good job of assessing the problem. It sounds like the float valve in the carb is the likely problem. This would overfill the carb when sitting, flooding the engine and the pressure in the bulb pump would go down as the fuel leaked out. Float valve should be investigated and that should Fixya!
Mar 13, 2009 | Boating
Harley Davidson KNG America 026711 Harley-Davidson Fat Boy Replica Phone Logo
60 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
