Question about Kitchen Ranges
Oven will not ignite
Tappen Model 32-1272
  • dflee48 May 23, 2008
    This model is 32-1272-10. This is a gas range.
    I have replaced the igniter but there still is no fire.
    I have replaced the igniter and there is no glow at all. A new Tstat is $100, is there a way to test the old one? Also, what are the chances it's the switch & how do I test to see?
  • 3,422 Answers
Is this an electric range or gas range?
Posted on May 23, 2008
  • Priya darshan May 23, 2008
    if the
    igniter is weak, if it glows red but doesn't get hot enough, or if it's
    burned out, the gas doesn't flow to the burner and the burner won't
    ignite. If this is the problem, you may need to replace either the
    igniter or the gas safety valve. Usually the igniter is to blame.
    Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
    Please CLICK HERE
    It will help you out with the testing the Tstat
    What is the model #
    Hello Todd;
    My name is Peter I am a retired field service appliance technician.
    Your model number should be on a metal label when you open the oven door.
    The element you have referenced is for ranges, including Tappan range model 31-1049-00-01.
    Dec 31, 2014 | Electrolux Tappen Electric Range Stove...
    I need a baking element for the tappen oven model number 486847a. The stove serial number is VF41807648. Can you help
    Go to you will need the model number and serial number and place an enquiry. They will get back to you.
    hope this is helpful
    Jun 05, 2011 | Ovens
    My 30 year old wall Tappen oven, the pitot is lit but no gas comes through to lite oven.
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or
    Oven not Heating
    Oven Problems Replacing the Igniter
    Mar 07, 2011 | Tappan Ovens
    I have a tappen model 32-2642-23/02 gas stove the oven igniter has been taking a whiloe to light as in minutes. now it seems not to want to light. the igniter glows and I smell the gas but not lighting.
    Igniters grow weak with age and occasionally need to be replaced. Just because an igniter glows, does not mean it is good. If you are experiencing longer ignition times, or no ignition, this is most likely the case. The following link explains a little theory about these igniters and how to replace one:
    Replacement parts (if required) can be purchased at any of the following websites:
    Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need.
    A replacement igniter part number for the model you have listed is 5303935066 and costs about $20-$25.
    If you have any questions please post back and let me know. I hope this helps you.
    Sep 08, 2010 | Tappan TGF320 Gas Kitchen Range
    Tappen oven lites then goes out after 30-40 seconds
    The problem is the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
    Jun 04, 2010 | Ovens
    Locked self cleaning oven after cleaning model TAPPEN
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
    May 11, 2010 | Hotpoint SY21 Style Line Gas Single Oven
    Gas oven(tappen) with broiler draw. oven will not light, no pilot
    if this is fairly new, there is a hot surface ignitor near the back of the burner in the bottom part of the oven. This can go bad. There is a connector that can be pulled apart where the ignitor meets the wiring harness. Ohm out the ignitor or have someone with a meter ohm it out. There should be resistance and not open. If open the ignitor should be replaced. If you have a broiling element, turn that on. If the broil element comes on then the ignitor is almost for sure the problem.
    Nov 21, 2009 | Ovens
    The pilot light works and gas in oven is on, but no gas ingition
    bad thermal bulb, try moving the bulb into the flame more.
    Jun 25, 2009 | Ovens
    Tappen model TGO356BCW top oven
    replace the igintor. its not working properly. no doubt you have a bad ignitor
    Mar 15, 2008 | Tappan TGF320 Gas Kitchen Range
    Constant Gas odor
    Constant gas odors is nothing to let go. You should have a technician check it out right away and turn the gas off to the unit.
    Oct 07, 2007 | Tappan TGF320 Gas Kitchen Range
    Kitchen Ranges Logo
    108 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
