Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
HP Laptop will not start
The laptop blue lights flash and go back out; the system will not start.
    Champion:
  • 207 Answers
Unplug and repulg the batteries and adaptor and then see
conect teh laptop wd adaptor wd out the bat and then see
even after these it doesnt work ..laptop needs to go for the repair
Posted on May 22, 2008
My HP 210-3070NR won't start. A blue light at the
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Mar 03, 2013 | Computers & Internet
Have a hp g60 -117us laptop after a bios flash laptop will not show a display it is only a black screen and only lights on when its turned on is power,touchpad and the first led that has a sympol of a...
Why did you flash the bios? Did you flash it with an upgraded bios that you downloaded from the HP Compaq site for your model and your operating system? When you turn on the laptop immediately start hitting the F8 Key repeatedly to see if it shows you the SAFE Mode option. If so select Safe Mode and see if it boots.
Are there any blinking lights or beeps? This is very strange. Try removing the battery and the power cord, then press and hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and see if it boots. If it does you had a static buildup in the laptop and you released it by holding the power button for 30 seconds. If it boots, put the battery back in.
if all fails you can try to see if your system will go into System Recovery when you press the Power Button immediately hit the F10 or F11 keys repeatedly. If so you can set your system back to the way it was when your purchased it. That means you will lose all your data, documents, music, pictures and videos.
Mar 21, 2012 | HP Compaq 6735s Notebook PC KS088UTABA$247...
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Hi my hp 6735s laptop has just started turning itself off when knocked or moved slightly. When you try and power back up the orange light around where the power lead plugs into the laptop flashes about 10...
Check the power cord at the connector. Hp has a problem with the cords breaking internally. I had a problem with mine and found that if I played with the cord then it worked for a while. I ended up buying a new power supply.
May 26, 2010 | HP Compaq 6735s Notebook
Have a HP dv9205us. Laptop started shutting down... then would not power up. AC light is lit and battery is charged. Power and HDD light would flash once when power button was pushed. Installed tested MB...
Please check it another display i mean a monitor.When its come other monitor may be fault your laptop TFT.Or it not OK may be fault laptop motherboard.Repair it by a good technician,who live in your area.
Dec 28, 2009 | HP Pavilion dv9000z Notebook
The blue & 3 amber light flashing on the battery indicator
The battery has an internal failure. While it may still run the system, the only way to stop the LED indication is to replace the battery.
Oct 24, 2009 | Dell Inspiron 1100 Notebook
I have an HP Pavilion 9000 that was working just fine. We powered it down for the day and when we went to start it up the next day it would not start. Blue light is lit where power supply plugs into...
That a nice computer you have there. Based on your description, my guess is you have a bad power supply.
About a $300 fix if you send back to HP. Which is what I had to do a while back.
Oct 20, 2009 | Compaq Laptop Keyboard for HP Pavilion...
Compaq laptop will not power up
try taking the battery out, make sure the ac adaptor is not connected, hold down the power button for 60 secs and then put the battery back in and try turning it on.
Sep 14, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
